Saltar al contenido principal
Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement
Qué necesitas
Resumen del Video
  1. Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, SIM and Memory Cards: paso 1, imagen 1 de 3 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, SIM and Memory Cards: paso 1, imagen 2 de 3 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, SIM and Memory Cards: paso 1, imagen 3 de 3
    • This is Samsung Galaxy Grand Neo Plus i9060i with broken screen.
    • Remove the battery and any installed SIM and memory cards.
  2. Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Rear Cover 1: paso 2, imagen 1 de 3 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Rear Cover 1: paso 2, imagen 2 de 3 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Rear Cover 1: paso 2, imagen 3 de 3
    • There are 12x small Phillips screws, remove them.
    • With a plastic tool start the disassembling from the bottom side.
    • You can use more then one plastic tool.
  3. Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Rear Cover 2: paso 3, imagen 1 de 2 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Rear Cover 2: paso 3, imagen 2 de 2
    • The rear bezel is locked to the frame near to the battery connector. Use a tool with a sharp tip and unhook it.
    • Now you can separate the rear bezel.
    • This is the Loudspeaker (in case if you want to change it).
  4. Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Logic Board: paso 4, imagen 1 de 3 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Logic Board: paso 4, imagen 2 de 3 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Logic Board: paso 4, imagen 3 de 3
    • Remove one Phillips screw.
    • Disconnect:
    • Vloume UP/DWN buttons flex cable and Power ON button flex cable.
    • LCD flex cable
    • Front camera
    • Audio jack flex cable
    • Now gently remove the logic board.
  5. Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Front Camera: paso 5, imagen 1 de 2 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Front Camera: paso 5, imagen 2 de 2
    • Remove the front camera.
    • Disconnect the touchscreen flex cable and unstuck it from the middle frame.
  6. Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Touch Screen Removal - Part 1: paso 6, imagen 1 de 3 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Touch Screen Removal - Part 1: paso 6, imagen 2 de 3 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Touch Screen Removal - Part 1: paso 6, imagen 3 de 3
    • At the bottom side, under the touch screen glass is the menu buttons flex cable. Be careful for it when you separating the glass from the frame.
    • Warm the glass. This will soften the adhesive tape. You can use hot air gun or hair dryer.
    • With a plastic tool start the separation at the upper side.
  7. Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Touch Screen Removal - Part 2: paso 7, imagen 1 de 3 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Touch Screen Removal - Part 2: paso 7, imagen 2 de 3 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Touch Screen Removal - Part 2: paso 7, imagen 3 de 3
    • You can warm the glass again to separate the glass easier.
    • Gently unstuck the menu buttons flex cable and remove the glass.
  8. Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Cleaning: paso 8, imagen 1 de 3 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Cleaning: paso 8, imagen 2 de 3 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Cleaning: paso 8, imagen 3 de 3
    • There is a small plate in the touch screen flex cable slot. Remove it to allow the flex cable of the new touch screen to pass.
    • Remove the remnants of the adhesive sticker and clean the LCD.
  9. Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Installation of the new Touch Screen: paso 9, imagen 1 de 3 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Installation of the new Touch Screen: paso 9, imagen 2 de 3 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Installation of the new Touch Screen: paso 9, imagen 3 de 3
    • Install the new touch screen and start with the reassembling.
  10. Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement: paso 10, imagen 1 de 1
    • That's all. Thanks!
Conclusión
29 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
191,882 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
321 Miembros
1,516 Guías creadas
Un comentario
very much helpful..this guide saved my repairing charge...this page is awesome..
Pravesh - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 37
Todo El Tiempo: 16,735
