Saltar al contenido principal
Samsung Galaxy Fame S6812i Camera Replacement
Qué necesitas
  1. Samsung Galaxy Fame S6812i Camera Replacement, Remove the battery cover: paso 1, imagen 1 de 1
    • Turn the phone off and make sure your hands are clean. Use your thumb nail or a plastic spudger to pry open the back cover,
  2. Samsung Galaxy Fame S6812i Camera Replacement, Remove the battery: paso 2, imagen 1 de 1
    • Use the plastic opening tool or your thumb nail to lift the battery out of the receptacle.
  3. Samsung Galaxy Fame S6812i Camera Replacement, Removing screws and stickers: paso 3, imagen 1 de 3 Samsung Galaxy Fame S6812i Camera Replacement, Removing screws and stickers: paso 3, imagen 2 de 3 Samsung Galaxy Fame S6812i Camera Replacement, Removing screws and stickers: paso 3, imagen 3 de 3
    • Remove the five 4 mm screws with a Phillips#00 screwdriver.
    • Make sure you remove the sticker hiding the screw on the left bottom corner.
  4. Samsung Galaxy Fame S6812i Camera Replacement, Removing the mid-frame.: paso 4, imagen 1 de 2 Samsung Galaxy Fame S6812i Camera Replacement, Removing the mid-frame.: paso 4, imagen 2 de 2
    • Using the plastic opening tool pry into the bezel to remove the mid-frame
    • Continue moving the plastic opening tool around the mid-frame to separate it from the display assembly.
    • Be gentle the plastic mounting clips are very fragile. Pay extra attention when working around the volume button.
  5. Samsung Galaxy Fame S6812i Camera Replacement: paso 5, imagen 1 de 1
    • After separating the two frames, you will have access to the camera
  6. Samsung Galaxy Fame S6812i Camera Replacement: paso 6, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Pull the camera off the system by using the tweezers. Perform this step with caution.
Conclusión
6 personas más completaron esta guía.
Charles
Miembro Desde 10/07/14
133 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 8-2, Leahy Fall 2014 Miembro de USF Tampa, Team 8-2, Leahy Fall 2014
USFT-LEAHY-F14S8G2
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 17
Todo El Tiempo: 1,009
