Saltar al contenido principal
Samsung Galaxy Express 3 Screen Replacement
Qué necesitas
  1. Samsung Galaxy Express 3 Screen Replacement, Battery: paso 1, imagen 1 de 2 Samsung Galaxy Express 3 Screen Replacement, Battery: paso 1, imagen 2 de 2
    • Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
  2. Samsung Galaxy Express 3 Screen Replacement: paso 2, imagen 1 de 3 Samsung Galaxy Express 3 Screen Replacement: paso 2, imagen 2 de 3 Samsung Galaxy Express 3 Screen Replacement: paso 2, imagen 3 de 3
    • Once the cover is removed, locate the battery that reads "SAMSUNG."
    • Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
    • Do not use a metal tool, as it can cause injury.
  3. Samsung Galaxy Express 3 Screen Replacement, Screen: paso 3, imagen 1 de 2 Samsung Galaxy Express 3 Screen Replacement, Screen: paso 3, imagen 2 de 2
    • Use a Plastic Prying Tool (such as a spudger) to pop out piece shown.
  4. Samsung Galaxy Express 3 Screen Replacement: paso 4, imagen 1 de 1
    • Detach the screen connector.
  5. Samsung Galaxy Express 3 Screen Replacement: paso 5, imagen 1 de 2 Samsung Galaxy Express 3 Screen Replacement: paso 5, imagen 2 de 2
    • Use a blow dryer or heating pad to heat up the screen.
    • Do not skip this step, as it may result in a broken screen and/or LCD.
    • This step loosens the glue holding the screen in place.
  6. Samsung Galaxy Express 3 Screen Replacement: paso 6, imagen 1 de 3 Samsung Galaxy Express 3 Screen Replacement: paso 6, imagen 2 de 3 Samsung Galaxy Express 3 Screen Replacement: paso 6, imagen 3 de 3
    • Use a Thin Plastic Tool (such as a guitar pick) or Plastic Prying Tool (such as a spudger) to lift out the glass digitizer and LCD screen around the edges.
    • Do this slowly and carefully, as both parts can crack very easily.
    • Ensure your tool is plastic, as a metal tool can damage the screen easily.
Conclusión
7 personas más completaron esta guía.
2 comentarios
My friend set on his phone the screen is broken. The phone will come on but the screen will not light up.
Rudolph Mc Alister - Contestar
Same! For TWO phones now… have you had any luck on any suggestions or figuring anything out???
Faith Dockery -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 3,530
