Saltar al contenido principal
Samsung Galaxy Express 3 Back and Recent Apps button Replacement
Qué necesitas
  1. Samsung Galaxy Express 3 Back and Recent Apps button Replacement, Battery: paso 1, imagen 1 de 2 Samsung Galaxy Express 3 Back and Recent Apps button Replacement, Battery: paso 1, imagen 2 de 2
    • Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
  2. Samsung Galaxy Express 3 Back and Recent Apps button Replacement: paso 2, imagen 1 de 3 Samsung Galaxy Express 3 Back and Recent Apps button Replacement: paso 2, imagen 2 de 3 Samsung Galaxy Express 3 Back and Recent Apps button Replacement: paso 2, imagen 3 de 3
    • Once the cover is removed, locate the battery that reads "SAMSUNG."
    • Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
    • Do not use a metal tool, as it can cause injury.
  3. Samsung Galaxy Express 3 Back and Recent Apps button Replacement, Screen: paso 3, imagen 1 de 2 Samsung Galaxy Express 3 Back and Recent Apps button Replacement, Screen: paso 3, imagen 2 de 2
    • Use a Plastic Prying Tool (such as a spudger) to pop out piece shown.
  4. Samsung Galaxy Express 3 Back and Recent Apps button Replacement: paso 4, imagen 1 de 1
    • Detach the screen connector.
  5. Samsung Galaxy Express 3 Back and Recent Apps button Replacement: paso 5, imagen 1 de 2 Samsung Galaxy Express 3 Back and Recent Apps button Replacement: paso 5, imagen 2 de 2
    • Use a blow dryer or heating pad to heat up the screen.
    • Do not skip this step, as it may result in a broken screen and/or LCD.
    • This step loosens the glue holding the screen in place.
  6. Samsung Galaxy Express 3 Back and Recent Apps button Replacement: paso 6, imagen 1 de 3 Samsung Galaxy Express 3 Back and Recent Apps button Replacement: paso 6, imagen 2 de 3 Samsung Galaxy Express 3 Back and Recent Apps button Replacement: paso 6, imagen 3 de 3
    • Use a Thin Plastic Tool (such as a guitar pick) or Plastic Prying Tool (such as a spudger) to lift out the glass digitizer and LCD screen around the edges.
    • Do this slowly and carefully, as both parts can crack very easily.
    • Ensure your tool is plastic, as a metal tool can damage the screen easily.
  7. Samsung Galaxy Express 3 Back and Recent Apps button Replacement, Back and Recent Apps Touch Sensor Button(s): paso 7, imagen 1 de 2 Samsung Galaxy Express 3 Back and Recent Apps button Replacement, Back and Recent Apps Touch Sensor Button(s): paso 7, imagen 2 de 2
    • Use a plastic tool to remove back and/or recent tabs circuit buttons.
    • Use a plastic tool as a metal tool can be dangerous to the phone or you.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 550
