Saltar al contenido principal
Samsung Galaxy Core Prime Screen Replacement
Qué necesitas
  1. Samsung Galaxy Core Prime Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the smartphone off by using the power button on the right-hand side.
  2. Samsung Galaxy Core Prime Screen Replacement: paso 2, imagen 1 de 1
    • Turn the smartphone over so that the rear camera is face up.
  3. Samsung Galaxy Core Prime Screen Replacement: paso 3, imagen 1 de 1
    • Use your fingernail or a flat tool to lift the back cover.
  4. Samsung Galaxy Core Prime Screen Replacement: paso 4, imagen 1 de 2 Samsung Galaxy Core Prime Screen Replacement: paso 4, imagen 2 de 2
    • Locate the battery near the bottom of the phone. The battery is square, flat, and is labeled 'SAMSUNG'.
  5. Samsung Galaxy Core Prime Screen Replacement: paso 5, imagen 1 de 1
    • Use your fingernail or a flat tool to lift the battery out.
  6. Samsung Galaxy Core Prime Screen Replacement, Screen: paso 6, imagen 1 de 2 Samsung Galaxy Core Prime Screen Replacement, Screen: paso 6, imagen 2 de 2
    • Use the Phillips #00 screwdriver to remove the eight 4 mm screws from the midframe.
  7. Samsung Galaxy Core Prime Screen Replacement: paso 7, imagen 1 de 1
    • Use a heat gun or hair dryer to loosen the adhesive between the midframe and the rest of the device.
    • Take care when using these heat tools.
  8. Samsung Galaxy Core Prime Screen Replacement: paso 8, imagen 1 de 2 Samsung Galaxy Core Prime Screen Replacement: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    iFixit Opening Tool
    $1.99
    Comprar
  9. Samsung Galaxy Core Prime Screen Replacement: paso 9, imagen 1 de 2 Samsung Galaxy Core Prime Screen Replacement: paso 9, imagen 2 de 2
    • Use tweezers to disconnect the power ribbon from the motherboard.
  10. Samsung Galaxy Core Prime Screen Replacement: paso 10, imagen 1 de 2 Samsung Galaxy Core Prime Screen Replacement: paso 10, imagen 2 de 2
    • Use tweezers or your hand to remove the audiojack.
  11. Samsung Galaxy Core Prime Screen Replacement: paso 11, imagen 1 de 1
    iFixit Opening Tool
    $1.99
    Comprar
  12. Samsung Galaxy Core Prime Screen Replacement: paso 12, imagen 1 de 1
    iFixit Opening Tool
    $1.99
    Comprar
    • Lift the plastic panel that separates the digitizer and the motherboard with an iFixit Opening Tool
  13. Samsung Galaxy Core Prime Screen Replacement: paso 13, imagen 1 de 3 Samsung Galaxy Core Prime Screen Replacement: paso 13, imagen 2 de 3 Samsung Galaxy Core Prime Screen Replacement: paso 13, imagen 3 de 3
    iFixit Opening Tool
    $1.99
    Comprar
  14. Samsung Galaxy Core Prime Screen Replacement: paso 14, imagen 1 de 2 Samsung Galaxy Core Prime Screen Replacement: paso 14, imagen 2 de 2
    • Use tweezers to disconnect the digitizer.
Conclusión
7 personas más completaron esta guía.
Cody Coombs
Miembro Desde 10/02/18
257 Reputación
1 Guía escrita
Un comentario
What if the phone does not come back on after assembly
nfl.ny.la.313 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 44
Todo El Tiempo: 2,500
