Saltar al contenido principal
Samsung Galaxy Core Prime Back Camera Replacement
Qué necesitas
  1. Samsung Galaxy Core Prime Back Camera Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the smartphone off by using the power button on the right-hand side.
  2. Samsung Galaxy Core Prime Back Camera Replacement: paso 2, imagen 1 de 1
    • Turn the smartphone over so that the rear camera is face up.
  3. Samsung Galaxy Core Prime Back Camera Replacement: paso 3, imagen 1 de 1
    • Use your fingernail or a flat tool to lift the back cover.
  4. Samsung Galaxy Core Prime Back Camera Replacement: paso 4, imagen 1 de 2 Samsung Galaxy Core Prime Back Camera Replacement: paso 4, imagen 2 de 2
    • Locate the battery near the bottom of the phone. The battery is square, flat, and is labeled 'SAMSUNG'.
  5. Samsung Galaxy Core Prime Back Camera Replacement: paso 5, imagen 1 de 1
    • Use your fingernail or a flat tool to lift the battery out.
  6. Samsung Galaxy Core Prime Back Camera Replacement, Rear Camera: paso 6, imagen 1 de 2 Samsung Galaxy Core Prime Back Camera Replacement, Rear Camera: paso 6, imagen 2 de 2
    • Use a Phillips #00 screw driver to remove all eight 4mm screws from the midframe.
  7. Samsung Galaxy Core Prime Back Camera Replacement: paso 7, imagen 1 de 1
    • Heat the frame with a heat gun or hair dryer until the adhesive is loose.
    • Take care when using these heat tools.
  8. Samsung Galaxy Core Prime Back Camera Replacement: paso 8, imagen 1 de 1
    Herramienta utilizada en este paso:
    iFixit Opening Tool
    $1.99
    Comprar
  9. Samsung Galaxy Core Prime Back Camera Replacement: paso 9, imagen 1 de 2 Samsung Galaxy Core Prime Back Camera Replacement: paso 9, imagen 2 de 2
    • Disconnect the power ribbon on the left side of the phone either with your fingers or tweezers
  10. Samsung Galaxy Core Prime Back Camera Replacement: paso 10, imagen 1 de 1
    iFixit Opening Tool
    $1.99
    Comprar
  11. Samsung Galaxy Core Prime Back Camera Replacement: paso 11, imagen 1 de 2 Samsung Galaxy Core Prime Back Camera Replacement: paso 11, imagen 2 de 2
    Metal Spudger
    $2.99
    Comprar
    • Turn the Motherboard over and disconnect the ribbon connecting the camera to the Motherboard with an iFixit Metal Spudger.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 16
Todo El Tiempo: 1,466
