Saltar al contenido principal
Samsung Galaxy Core Main and Front Cameras Replacement
Qué necesitas
Resumen del Video
  1. Samsung Galaxy Core Main and Front Cameras Replacement, Vibra Motor: paso 1, imagen 1 de 2 Samsung Galaxy Core Main and Front Cameras Replacement, Vibra Motor: paso 1, imagen 2 de 2
    • Switch-off the phone.
    • Remove the Battery cover and the battery.
    • Remove an inserted SIM and Memory cards.
  2. Samsung Galaxy Core Main and Front Cameras Replacement: paso 2, imagen 1 de 3 Samsung Galaxy Core Main and Front Cameras Replacement: paso 2, imagen 2 de 3 Samsung Galaxy Core Main and Front Cameras Replacement: paso 2, imagen 3 de 3
    • Remove 9x Phillips screws.
    • With a plastic tool remove the Back cover.
    • The Vibrator is on the other side of the back cover
  3. Samsung Galaxy Core Main and Front Cameras Replacement, Logic Board: paso 3, imagen 1 de 3 Samsung Galaxy Core Main and Front Cameras Replacement, Logic Board: paso 3, imagen 2 de 3 Samsung Galaxy Core Main and Front Cameras Replacement, Logic Board: paso 3, imagen 3 de 3
    • Disconnect one by one:
    • Earpiece/Loudspeaker/Audio Jack connector module flex cable
    • LCD Display flex cable
    • Charging Dock/Antenna/Mic module flex cable
    • Coaxial Antenna cable
    • Carefully remove the Logic Board.
  4. Samsung Galaxy Core Main and Front Cameras Replacement, Main and Front Cameras: paso 4, imagen 1 de 3 Samsung Galaxy Core Main and Front Cameras Replacement, Main and Front Cameras: paso 4, imagen 2 de 3 Samsung Galaxy Core Main and Front Cameras Replacement, Main and Front Cameras: paso 4, imagen 3 de 3
    • Main / Rear Camera
    • Front Camera
    • With a plastic tool open the Camera flex cable connector.
    • Carefully remove the camera.
Conclusión
7 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
192,056 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
321 Miembros
1,525 Guías creadas
3 comentarios
Hi, I have galaxy win and the front camera is too bad in quality, i want to replace front camera with galaxy core front camera which is very descent in compare to galaxy win. Please suggest
My email Id: shaikhyassar@gmail.com
Yassar Shaikh - Contestar
اكتب عربي
Mjd Mjd - Contestar
My mobile Sony m2 my camera low quality... Can I do anything for this problem??!
Mjd Mjd - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 4,533
