Saltar al contenido principal
Samsung Galaxy Camera Lens or Motherboard Replacement
Qué necesitas
  1. Samsung Galaxy Camera Lens or Motherboard Replacement, Lens or Motherboard: paso 1, imagen 1 de 1
    • Gather your camera and tools. Also make sure that the battery is removed before proceeding.
    • Follow battery replacement guide through step three to remove the battery.
  2. Samsung Galaxy Camera Lens or Motherboard Replacement: paso 2, imagen 1 de 3 Samsung Galaxy Camera Lens or Motherboard Replacement: paso 2, imagen 2 de 3 Samsung Galaxy Camera Lens or Motherboard Replacement: paso 2, imagen 3 de 3
    • Remove all seven 4 millimeter long screws using the PH000 screwdriver bit.
  3. Samsung Galaxy Camera Lens or Motherboard Replacement: paso 3, imagen 1 de 2 Samsung Galaxy Camera Lens or Motherboard Replacement: paso 3, imagen 2 de 2
    • Use plastic opening tool to remove the cover on the non-lens side of the camera.
  4. Samsung Galaxy Camera Lens or Motherboard Replacement: paso 4, imagen 1 de 3 Samsung Galaxy Camera Lens or Motherboard Replacement: paso 4, imagen 2 de 3 Samsung Galaxy Camera Lens or Motherboard Replacement: paso 4, imagen 3 de 3
    • Open the battery compartment and remove the 2 screws. Also remove the screw from the bottom of the camera after pulling off the white sticker concealing it. Removing these screws releases the bottom of the display assembly.
    • Starting at the non-lens side of the camera, use plastic opening tool to pry screen away from main housing on all sides.
  5. Samsung Galaxy Camera Lens or Motherboard Replacement: paso 5, imagen 1 de 2 Samsung Galaxy Camera Lens or Motherboard Replacement: paso 5, imagen 2 de 2
    • Use plastic opening tool to pull connector away from motherboard.
    • Remove screen completely and set aside.
  6. Samsung Galaxy Camera Lens or Motherboard Replacement: paso 6, imagen 1 de 2 Samsung Galaxy Camera Lens or Motherboard Replacement: paso 6, imagen 2 de 2
    • Using the plastic opening tool, disconnect the three connectors from the motherboard.
  7. Samsung Galaxy Camera Lens or Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the three 3.5 mm long screws (red circle markers) using the PH000 screwdriver bit.
    • Remove the four 2 mm long screws (orange circle markers) using the PH000 screwdriver bit.
  8. Samsung Galaxy Camera Lens or Motherboard Replacement: paso 8, imagen 1 de 2 Samsung Galaxy Camera Lens or Motherboard Replacement: paso 8, imagen 2 de 2
    • Remove the three 3 mm long screws connecting the lens unit to the main housing using the PH000 screwdriver bit.
    • Carefully remove the lens and motherboard from main housing.
  9. Samsung Galaxy Camera Lens or Motherboard Replacement: paso 9, imagen 1 de 3 Samsung Galaxy Camera Lens or Motherboard Replacement: paso 9, imagen 2 de 3 Samsung Galaxy Camera Lens or Motherboard Replacement: paso 9, imagen 3 de 3
    • Remove stickers off of connectors.
    • Open latch door on connectors.
    • Separate lens from motherboard.
    • Now you may replace either motherboard or lens with new part.
Conclusión
8 personas más completaron esta guía.
Keith Lipking
Miembro Desde 09/26/15
359 Reputación
1 Guía escrita
Equipo
IUPUI, Team 2-3, Wilson Fall 2015 Miembro de IUPUI, Team 2-3, Wilson Fall 2015
IUPUI-WILSON-F15S2G3
4 Miembros
4 Guías creadas
2 comentarios
Would love a video of this, as well.
David CrossmN - Contestar
Hey after you replace the motherboard do you just turn the camera on and it works?
Ive done it and some chinese characters show up in a dialog box...
Sam - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 3,160
