Introducción
When Using this Guide
Please note the circles on out pictures that indicate where screws are removed from, as most of the screw lengths are pertinent to reassembly.
Herramientas
Partes
No se especificaron partes.
Lift aside the casing for the battery using a plastic opening tool. This compartment is on the bottom of the camera, not under the lens.
The casing is highlighted in the red markup circle.
These steps follow completely: there is no need to reverse the order of steps to reassemble.
8 personas más completaron esta guía.
