Saltar al contenido principal
Samsung Galaxy Camera Battery Replacement
Qué necesitas
  1. Samsung Galaxy Camera Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Lift aside the casing for the battery using a plastic opening tool. This compartment is on the bottom of the camera, not under the lens.
    • The casing is highlighted in the red markup circle.
  2. Samsung Galaxy Camera Battery Replacement: paso 2, imagen 1 de 1
    • The slot for the battery should look like this. This is the case for the battery.
  3. Samsung Galaxy Camera Battery Replacement: paso 3, imagen 1 de 2 Samsung Galaxy Camera Battery Replacement: paso 3, imagen 2 de 2
    • Using plastic opening tool, slide battery capture latch back and allow battery to fall out.
    • Insert your replacement battery.
  4. Samsung Galaxy Camera Battery Replacement: paso 4, imagen 1 de 2 Samsung Galaxy Camera Battery Replacement: paso 4, imagen 2 de 2
    • After the battery has been replaced, close the battery casing.
    • Now replace the casing from step one. Success, the battery has been replaced!
Conclusión
These steps follow completely: there is no need to reverse the order of steps to reassemble.
8 personas más completaron esta guía.
Derek Brown
Miembro Desde 10/24/15
168 Reputación
1 Guía escrita
Equipo
IUPUI, Team 2-3, Wilson Fall 2015 Miembro de IUPUI, Team 2-3, Wilson Fall 2015
IUPUI-WILSON-F15S2G3
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 19
Ultimos 30 días: 99
Todo El Tiempo: 2,360
