Saltar al contenido principal
Samsung Galaxy Book Pro 15" Rubber Feet Replacement
Qué necesitas
  1. Samsung Galaxy Book Pro 15" Rubber Feet Replacement, Remove the rubber feet: paso 1, imagen 1 de 3 Samsung Galaxy Book Pro 15" Rubber Feet Replacement, Remove the rubber feet: paso 1, imagen 2 de 3 Samsung Galaxy Book Pro 15" Rubber Feet Replacement, Remove the rubber feet: paso 1, imagen 3 de 3
    • Before you begin, power down your laptop and unplug it.
    • There are two kinds of rubber feet along the top and bottom of the rear case. Keep track of their position as you remove them.
    • Insert an opening pick between the rubber foot and the rear case.
    • Pry up with the opening pick to release the clips securing the foot.
    • Remove the foot.
    • Repeat this procedure for the three remaining feet.
    • During reassembly, press the feet into their correct slot to reinsert them. Mismatched feet won't fit correctly.
Conclusión
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
Alex Diaz-Kokaisl
Miembro Desde 01/16/22
119,326 Reputación
549 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,817 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 715
