Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Samsung Galaxy Amp 2 Speaker Replacement
Qué necesitas
  1. Samsung Galaxy Amp 2 Speaker Replacement, Battery: paso 1, imagen 1 de 2 Samsung Galaxy Amp 2 Speaker Replacement, Battery: paso 1, imagen 2 de 2
    • Insert your fingernail or an opening tool into the divot on the side of the phone. The divot is located to the left of the rear-facing camera.
    • Lift upwards and gently pry the rear panel off of the phone.
  2. Samsung Galaxy Amp 2 Speaker Replacement: paso 2, imagen 1 de 3 Samsung Galaxy Amp 2 Speaker Replacement: paso 2, imagen 2 de 3 Samsung Galaxy Amp 2 Speaker Replacement: paso 2, imagen 3 de 3
    • Insert a fingernail or plastic opening tool into the gap in the bottom right corner of the battery and lift upward.
    • Grip the battery and safely remove it from the phone.
  3. Samsung Galaxy Amp 2 Speaker Replacement, Screen: paso 3, imagen 1 de 3 Samsung Galaxy Amp 2 Speaker Replacement, Screen: paso 3, imagen 2 de 3 Samsung Galaxy Amp 2 Speaker Replacement, Screen: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    $3.99
    • Using angled tweezers, lift the small rectangular guard at upper right corner of the phone.
    • Disconnect the connector piece from the back panel.
  4. Samsung Galaxy Amp 2 Speaker Replacement: paso 4, imagen 1 de 1
    • Apply heat from heat gun or blow dryer on periphery of the screen for one to two minutes.
  5. Samsung Galaxy Amp 2 Speaker Replacement: paso 5, imagen 1 de 3 Samsung Galaxy Amp 2 Speaker Replacement: paso 5, imagen 2 de 3 Samsung Galaxy Amp 2 Speaker Replacement: paso 5, imagen 3 de 3
    • Use four plastic opening tools to gently pry off the screen.
    • Optional: Use a suction tool to pull the screen off.
  6. Samsung Galaxy Amp 2 Speaker Replacement, Motherboard: paso 6, imagen 1 de 3 Samsung Galaxy Amp 2 Speaker Replacement, Motherboard: paso 6, imagen 2 de 3 Samsung Galaxy Amp 2 Speaker Replacement, Motherboard: paso 6, imagen 3 de 3
    • Unscrew the nine 4.5mm PH screws using a screwdriver with a PH000 bit.
    • Push from the back panel to remove the bottom part of the motherboard.
    • Push from the front panel to remove the top part of the motherboard.
  7. Samsung Galaxy Amp 2 Speaker Replacement, Speaker: paso 7, imagen 1 de 2 Samsung Galaxy Amp 2 Speaker Replacement, Speaker: paso 7, imagen 2 de 2
    • Gently pull the black piece that is connected to the top of the motherboard. This is the speaker.
Conclusión
Una persona más ha completado esta guía.
Cory Nickolatos
Miembro Desde 07/12/18
430 Reputación
4 Guías creadas
Equipo
UW Tacoma, Team S1-G1, Cardinal Summer 2018 Miembro de UW Tacoma, Team S1-G1, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G1
Miembros de 4
5 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 599
