Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Samsung Galaxy Amp 2 Home Button Replacement
Qué necesitas
  1. Samsung Galaxy Amp 2 Home Button Replacement, Battery: paso 1, imagen 1 de 2 Samsung Galaxy Amp 2 Home Button Replacement, Battery: paso 1, imagen 2 de 2
    • Insert your fingernail or an opening tool into the divot on the side of the phone. The divot is located to the left of the rear-facing camera.
    • Lift upwards and gently pry the rear panel off of the phone.
  2. Samsung Galaxy Amp 2 Home Button Replacement: paso 2, imagen 1 de 3 Samsung Galaxy Amp 2 Home Button Replacement: paso 2, imagen 2 de 3 Samsung Galaxy Amp 2 Home Button Replacement: paso 2, imagen 3 de 3
    • Insert a fingernail or plastic opening tool into the gap in the bottom right corner of the battery and lift upward.
    • Grip the battery and safely remove it from the phone.
  3. Samsung Galaxy Amp 2 Home Button Replacement, Screen: paso 3, imagen 1 de 3 Samsung Galaxy Amp 2 Home Button Replacement, Screen: paso 3, imagen 2 de 3 Samsung Galaxy Amp 2 Home Button Replacement, Screen: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    $3.99
    • Using angled tweezers, lift the small rectangular guard at upper right corner of the phone.
    • Disconnect the connector piece from the back panel.
  4. Samsung Galaxy Amp 2 Home Button Replacement: paso 4, imagen 1 de 1
    • Apply heat from heat gun or blow dryer on periphery of the screen for one to two minutes.
  5. Samsung Galaxy Amp 2 Home Button Replacement: paso 5, imagen 1 de 3 Samsung Galaxy Amp 2 Home Button Replacement: paso 5, imagen 2 de 3 Samsung Galaxy Amp 2 Home Button Replacement: paso 5, imagen 3 de 3
    • Use four plastic opening tools to gently pry off the screen.
    • Optional: Use a suction tool to pull the screen off.
  6. Samsung Galaxy Amp 2 Home Button Replacement, Motherboard: paso 6, imagen 1 de 3 Samsung Galaxy Amp 2 Home Button Replacement, Motherboard: paso 6, imagen 2 de 3 Samsung Galaxy Amp 2 Home Button Replacement, Motherboard: paso 6, imagen 3 de 3
    • Unscrew the nine 4.5mm PH screws using a screwdriver with a PH000 bit.
    • Push from the back panel to remove the bottom part of the motherboard.
    • Push from the front panel to remove the top part of the motherboard.
  7. Samsung Galaxy Amp 2 Home Button Replacement, Home Button: paso 7, imagen 1 de 3 Samsung Galaxy Amp 2 Home Button Replacement, Home Button: paso 7, imagen 2 de 3 Samsung Galaxy Amp 2 Home Button Replacement, Home Button: paso 7, imagen 3 de 3
    • Pull the black tab that is located on the bottom of the motherboard.
    • Push the home button out of the black tab.
Conclusión
Una persona más ha completado esta guía.
Cory Nickolatos
Miembro Desde 07/12/18
415 Reputación
4 Guías creadas
Equipo
UW Tacoma, Team S1-G1, Cardinal Summer 2018 Miembro de UW Tacoma, Team S1-G1, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G1
Miembros de 4
5 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 29
Todo El Tiempo: 663
