Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Use this guide to remove or replace the battery in your Samsung Galaxy Amp 2. If you are having any problems with your battery, you may want to remove it to check for damage or replace it. You will only need your fingernails or a plastic opening tool for this guide.
Partes
No se especificaron partes.
  1. Insert your fingernail or an opening tool into the divot on the side of the phone. The divot is located to the left of the rear-facing camera. Lift upwards and gently pry the rear panel off of the phone.
    • Insert your fingernail or an opening tool into the divot on the side of the phone. The divot is located to the left of the rear-facing camera.
    • Lift upwards and gently pry the rear panel off of the phone.
  2. SALTEA LA ACTUALIZACIÓN
    Ahorra reparando con un kit todo en uno.
    Compra Kits de Reparación
  3. Insert a fingernail or plastic opening tool into the gap  in the bottom right corner of the battery and lift upward. Grip the battery and safely remove it from the phone. Grip the battery and safely remove it from the phone.
    • Insert a fingernail or plastic opening tool into the gap in the bottom right corner of the battery and lift upward.
    • Grip the battery and safely remove it from the phone.
Conclusión
Miguel Sheets
Miembro Desde 12/07/18
249 Reputación
1 Guía escrita
Equipo
UW Tacoma, Team S1-G1, Cardinal Summer 2018 Miembro de UW Tacoma, Team S1-G1, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G1
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 586
