Saltar al contenido principal
Samsung Galaxy Alpha microSIM Card Replacement
  1. Samsung Galaxy Alpha microSIM Card Replacement, Removing the Back Panel: paso 1, imagen 1 de 3 Samsung Galaxy Alpha microSIM Card Replacement, Removing the Back Panel: paso 1, imagen 2 de 3 Samsung Galaxy Alpha microSIM Card Replacement, Removing the Back Panel: paso 1, imagen 3 de 3
    • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
    • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
    • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
  2. Samsung Galaxy Alpha microSIM Card Replacement, Battery: paso 2, imagen 1 de 2 Samsung Galaxy Alpha microSIM Card Replacement, Battery: paso 2, imagen 2 de 2
    • Make sure the device is powered down before moving forward.
    • Since the NFC antenna is glued to the battery, make sure the replacement also includes one.
    • Locate the slot at the base of the battery and insert your thumb.
    • Push slightly toward the battery and out, away from the phone to free the battery.
  3. Samsung Galaxy Alpha microSIM Card Replacement, microSIM Card: paso 3, imagen 1 de 1
    • Remove your Micro SIM card from the slot shown.
Conclusión
11 personas más completaron esta guía.
Tyler
Miembro Desde 01/22/15
769 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 20-17, Maness Winter 2015 Miembro de Cal Poly, Team 20-17, Maness Winter 2015
CPSU-MANESS-W15S20G17
Miembros de 4
5 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 2,511
