Saltar al contenido principal
Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement
Qué necesitas
Resumen del Video
  1. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement, Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera: paso 1, imagen 1 de 2 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement, Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera: paso 1, imagen 2 de 2
    • Switch off the phone.
    • Remove the battery and any installed SIM and memory card.
  2. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 2, imagen 1 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 2, imagen 2 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 2, imagen 3 de 3
    • Remove the 7 Phillips screws.
    • Use a plastic tool to remove the back cover.
    • vibrating motor
  3. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 3, imagen 1 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 3, imagen 2 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 3, imagen 3 de 3
    • Disconnect the earpiece & light sensor flex cable.
    • Take off the Volume Up/Down buttons flex cable.
    • Do the same with the Power button flex cable.
    • Be careful don't brake the flex cables.
  4. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 4, imagen 1 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 4, imagen 2 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 4, imagen 3 de 3
    • Lift the microphone.
    • Lift the board from the right side and disconnect the LCD display flex cable.
    • Remove the board from the middle frame.
  5. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 5, imagen 1 de 2 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 5, imagen 2 de 2
    • This is the main camera.
  6. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 6, imagen 1 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 6, imagen 2 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 6, imagen 3 de 3
    • This is the loudspeaker & audio jack connector module.
  7. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 7, imagen 1 de 2 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 7, imagen 2 de 2
    • Loudspeaker and light sensor module,
  8. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 8, imagen 1 de 2 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 8, imagen 2 de 2
    • Disconnect the touch screen flex cable.
  9. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 9, imagen 1 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 9, imagen 2 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 9, imagen 3 de 3
    • Use a hair dryer and warm the touch screen glass to make adhesive soften.
    • Use a plastic tool for separating the glass from the middle frame.
  10. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 10, imagen 1 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 10, imagen 2 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 10, imagen 3 de 3
    • Again by using a plastic tool, separate the LCD display from the middle frame.
  11. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 11, imagen 1 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 11, imagen 2 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 11, imagen 3 de 3
    • Clean the middle frame and install the LCD display.
  12. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 12, imagen 1 de 2 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 12, imagen 2 de 2
    • Install the touch screen and start with reassembling.
  13. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: paso 13, imagen 1 de 1
    • That is all.
    • Did you do it successfully?
Conclusión
23 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
192,056 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
321 Miembros
1,525 Guías creadas
Un comentario
Amar touch ta lagbe
nj nazmul - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 31
Todo El Tiempo: 9,380
