Introducción
Changing the USB port for this model is tricky.
One option would be to replace the connector only, but a resin glue makes it difficult to unsolder the USB connector.
I therefore decided to replace the entire PCB.
However, but this proved to be also really tricky because the PCB is a rigid-flex board with a lot of very tiny flex parts, and I ended up braking the flex part around the jack connector while attempting to remove the PCB. I also damaged the screen while attempting to lift the glass.
So carry out this procedure with great caution!
Qué necesitas
Insert a SIM card eject tool, a SIM eject bit or a straightened paper clip into the hole on the SIM tray located at the left side of the phone.
Press firmly to eject the tray.
Remove the SIM card tray.
Prepare an iOpener and apply it to the back cover to soften the adhesive.
Insert the tip of an opening pick between the frame and the back cover at the bottom of the phone near the USB-C port.
If you can't get between the back cover and midframe with your opening pick, you can use a suction handle or strong tape to pull up the back cover to create a gap.
Slide the opening pick to the bottom right corner and leave it there.
Use the flat end of a spudger to pry up and disconnect the display flex cable on the bottom of the phone.
Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive beneath.
Insert a plastic card on the left edge into the gap between display and the phone assembly.
Press the plastic card in and slide it back and forth until you cut through the entire adhesive.
Once you are sure you cut through the adhesive, remove the four opening picks from the corners.
Disconnect the antenna connector at the lower right
Use a spudger to disconnect the main board connector from the rear side of the PCB.
Use the flat side of the spudger to unglue the microphone from its compartment. Be careful not to break the flex part.
Peel off the PCB from its compartment and lift it to the other side without pulling.
Proceed element by element, trying not to break the flex parts. Here you’ll notice I broke the flex surrounding the jack port.
Take care not to damage/disconnect the two flex cables connected to the buttons at each end of the PCB (circled in red on the photo)
Remove or raise the glass on the other side of the phone.
Peel off the two button connectors.
This is a view of the entire replacement board.
Note the flex parts circled in yellow on the photo: those are the most fragile parts of the PCB.
Place the new USB board in its casing
Plug the connector to the main board, below said board
Remove stickers from glued parts on new board
Remove the previous while filtering sticker under the buttons
Glue both backlight elements into their casing
At this point, there are 17 screws to be reassembled at the back of the phone
Glue screen and back cover back in place
Follow the instructions in reverse order to assemble the device.
3 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Un comentario
The tutorial is not accurate, because from step 20 phone model in photos is A510F (A5 2016) not A515 (A51 2019) , it has different shape PCB
