Qué necesitas
Resumen del Video
Display Touch Screen Digitizer Assembly with Frame for Samsung Galaxy A50
Heat up the back cover to loosen the adhesive.
To separate the back cover use a Suction Cup and plastic tools.
Remove the SIM tray.
Remove the Philips Screws.
Again use plastic tools to separate the middle frame.
First disconnect the Battery.
Test the new spare part before the installation.
Disconnect and remove the Main Flex Cable.
Remove the black Philips screw, it's shorter then the middle frame screws.
Disconnect the coaxial antenna cable.
Now you can remove the logic board.
First remove the Fingerprint sensor.
It's better to use hot air before to disassemble the sub-board.
Reminder - only plastic tools :)
4 personas más completaron esta guía.
