Saltar al contenido principal
Samsung Galaxy A5 (2017) Touchscreen and LCD Replacement
Qué necesitas
Instrucciones de Vídeo
Linea de Meta
41 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
fr en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
ian mdx
Miembro Desde 06/30/16
9,266 Reputación
17 Guías creadas
9Guía Comentarios
Good video!
I have a question though. What did you use to bull back the back partbof the phone at the end of the video? You simply heated the glue that was already there?
Mattia Rappuoli - Contestar
Please answer, what is the glue you used in the video? Thanks.
tcatt - Contestar
The glue used here is the B7000 glue, which can be found on this site under tools or from aliexpress.com.
However, it should be mentioned that it is not required to use other glue than the sticky tape than phone already has, unless you are serious about waterproofing. I removed 98% of all the sticky tape that was there hoping it would be easier to open later. Funny thing is that I still have to use heat lol. Hard to remove all that sticky.
lightmeupper - Contestar
The tool to pull back the cover is Suction Handle
Something tells me it may work with a 40-50mm diameter suction cup from dollar store as well :-)
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 72
Todo El Tiempo: 69,296
