Introducción
To replace your display, you will need the following items:
- Display assembly
- Hot air dryer or iHeater
- Opening Picks
- Spudger
- Screwdriver set
- Tweezers
Remove the SIM card
Heat the edges of the rear panel until you can just hold the device without burning yourself. Use a hairdryer, heat gun, or oven (I set an oven to 80ºC [175ºF] top/bottom heat, after about 3 minutes the right temperature was reached). The heat will soften the glue between the back and the frame.
Insert a flat plastic tool (e.g. pick or spudger) between the back and the frame.
Slowly work your way along the entire edge until the back is detached and you can lift it off. Lift the back slowly, and press the fingerprint sensor against the frame so that it detaches from the back and does not tear out.
Now the frame can be removed with the help of a spudger.
The best way to do this is to insert the spudger between the display and the frame from the SIM slot and then carefully pull it along the entire device.
Here you will hear some clicking, which means that the clips are coming loose.
Once all clips are released, the frame can be easily removed.
First, the battery should be unplugged, as there is still voltage on the components even though the device is switched off.
Next, all connections from the logic boards to the display and between the boards can be disconnected.
To do this, disconnect the large "main-sub" cable, the antenna, and the display flex.
To reassemble your device, follow the steps in reverse order.
Una persona más ha completado esta guía.
Un agradecimiento especial a estos traductores:
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
