Saltar al contenido principal
Samsung Galaxy A20e Display Assembly Replacement
Qué necesitas
Resumen del Video
  1. Samsung Galaxy A20e Display Assembly Replacement, Display Touch Screen Assembly Spare part: paso 1, imagen 1 de 2 Samsung Galaxy A20e Display Assembly Replacement, Display Touch Screen Assembly Spare part: paso 1, imagen 2 de 2
    • This is Display Touch Screen Assembly with Frame
  2. Samsung Galaxy A20e Display Assembly Replacement, Back Cover Removal: paso 2, imagen 1 de 3 Samsung Galaxy A20e Display Assembly Replacement, Back Cover Removal: paso 2, imagen 2 de 3 Samsung Galaxy A20e Display Assembly Replacement, Back Cover Removal: paso 2, imagen 3 de 3
    • Remove the SIM tray
    • To remove the back cover use a plastic opening tool
    • When you remove the back cover, press the Touch ID to unstick it from the back cover
  3. Samsung Galaxy A20e Display Assembly Replacement, Fingerprint Sensor Removal: paso 3, imagen 1 de 3 Samsung Galaxy A20e Display Assembly Replacement, Fingerprint Sensor Removal: paso 3, imagen 2 de 3 Samsung Galaxy A20e Display Assembly Replacement, Fingerprint Sensor Removal: paso 3, imagen 3 de 3
    • With a Phillips Screwdriver remove all the screws
    • With a Plastic Opening Tool:
    • Remove the Antenna Assembly
    • Disconnect and remove the Touch ID Fingerprint Sensor
  4. Samsung Galaxy A20e Display Assembly Replacement, Logic Board Cover Removal: paso 4, imagen 1 de 3 Samsung Galaxy A20e Display Assembly Replacement, Logic Board Cover Removal: paso 4, imagen 2 de 3 Samsung Galaxy A20e Display Assembly Replacement, Logic Board Cover Removal: paso 4, imagen 3 de 3
    • Remove the Logic Board Plastic Cover
    • Remove the Sup-board Plastic Cover
  5. Samsung Galaxy A20e Display Assembly Replacement, Test the New Spare part: paso 5, imagen 1 de 3 Samsung Galaxy A20e Display Assembly Replacement, Test the New Spare part: paso 5, imagen 2 de 3 Samsung Galaxy A20e Display Assembly Replacement, Test the New Spare part: paso 5, imagen 3 de 3
    • Its time to test the new spare part
    • Do not forget to disconnect the battery before you start working on the device.
  6. Samsung Galaxy A20e Display Assembly Replacement, Logic Board Removal - Part 1: paso 6, imagen 1 de 3 Samsung Galaxy A20e Display Assembly Replacement, Logic Board Removal - Part 1: paso 6, imagen 2 de 3 Samsung Galaxy A20e Display Assembly Replacement, Logic Board Removal - Part 1: paso 6, imagen 3 de 3
    • Disconnect the Battery
    • Disconnect the Sup-board Flex Cable
    • Disconnect the Coaxial Antenna Cables. Do it very carefully because you can easily damage them
  7. Samsung Galaxy A20e Display Assembly Replacement, Logic Board Removal - Part 2: paso 7, imagen 1 de 3 Samsung Galaxy A20e Display Assembly Replacement, Logic Board Removal - Part 2: paso 7, imagen 2 de 3 Samsung Galaxy A20e Display Assembly Replacement, Logic Board Removal - Part 2: paso 7, imagen 3 de 3
    • Remove the Sup-board Flex Cable
    • Disconnect the Volume buttons Flex Cable
    • Gently remove the Logic board. Be careful for the cameras
  8. Samsung Galaxy A20e Display Assembly Replacement, Sup-board removal: paso 8, imagen 1 de 3 Samsung Galaxy A20e Display Assembly Replacement, Sup-board removal: paso 8, imagen 2 de 3 Samsung Galaxy A20e Display Assembly Replacement, Sup-board removal: paso 8, imagen 3 de 3
    • Use Hot air to soften the adhesive and gently remove the sup-bord
    • Its better to use a plastic tools
  9. Samsung Galaxy A20e Display Assembly Replacement, Battery Removal: paso 9, imagen 1 de 3 Samsung Galaxy A20e Display Assembly Replacement, Battery Removal: paso 9, imagen 2 de 3 Samsung Galaxy A20e Display Assembly Replacement, Battery Removal: paso 9, imagen 3 de 3
    • To remove the Battery use a few drops of alcohol and warm the device.
  10. Samsung Galaxy A20e Display Assembly Replacement, Transfer the Receiver, Loudspeaker and the Vibration-motor: paso 10, imagen 1 de 3 Samsung Galaxy A20e Display Assembly Replacement, Transfer the Receiver, Loudspeaker and the Vibration-motor: paso 10, imagen 2 de 3 Samsung Galaxy A20e Display Assembly Replacement, Transfer the Receiver, Loudspeaker and the Vibration-motor: paso 10, imagen 3 de 3
    • Now you have to transfer:
    • Receiber
    • Vibromotor
    • Loudspeacker
    • Remove the transport tapes from:
    • Silicon Thermal Pad
    • Front Camera Hole
    • Use Hot Air to do this easily
  11. Samsung Galaxy A20e Display Assembly Replacement, Battery: paso 11, imagen 1 de 1
    • Use Double side Adhesive tape to install the battery to the new frame
  12. Samsung Galaxy A20e Display Assembly Replacement: paso 12, imagen 1 de 1
    • "All's Well That Ends Well."
Conclusión
20 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
194,021 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
327 Miembros
1,697 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 15
Ultimos 30 días: 63
Todo El Tiempo: 17,305
