Saltar al contenido principal
Introducción
Samsung A20e - Broken Screen Replacement
Partes
No se especificaron partes.
Resumen del Video
  1. This is Display Touch Screen Assembly with Frame This is Display Touch Screen Assembly with Frame
    • This is Display Touch Screen Assembly with Frame
  2. Remove the SIM tray To remove the back cover use a plastic opening tool When you remove the back cover, press the Touch ID to unstick it from the back cover
    • Remove the SIM tray
    • To remove the back cover use a plastic opening tool
    • When you remove the back cover, press the Touch ID to unstick it from the back cover
  3. With a Phillips Screwdriver remove all the screws With a Plastic Opening Tool: Remove the Antenna Assembly
    • With a Phillips Screwdriver remove all the screws
    • With a Plastic Opening Tool:
    • Remove the Antenna Assembly
    • Disconnect and remove the Touch ID Fingerprint Sensor
  4. Remove the Logic Board Plastic Cover Remove the Sup-board Plastic Cover Remove the Sup-board Plastic Cover
    • Remove the Logic Board Plastic Cover
    • Remove the Sup-board Plastic Cover
  5. Its time to test the new spare part Do not forget to disconnect the battery before you start working on the device. Do not forget to disconnect the battery before you start working on the device.
    • Its time to test the new spare part
    • Do not forget to disconnect the battery before you start working on the device.
  6. Disconnect the Battery Disconnect the Sup-board Flex Cable Disconnect the Coaxial Antenna Cables. Do it very carefully because you can easily damage them
    • Disconnect the Battery
    • Disconnect the Sup-board Flex Cable
    • Disconnect the Coaxial Antenna Cables. Do it very carefully because you can easily damage them
  7. Remove the Sup-board Flex Cable Disconnect the Volume buttons Flex Cable Gently remove the Logic board. Be careful for the cameras
    • Remove the Sup-board Flex Cable
    • Disconnect the Volume buttons Flex Cable
    • Gently remove the Logic board. Be careful for the cameras
  8. Use Hot air to soften the adhesive and gently remove the sup-bord Its better to use a plastic tools Its better to use a plastic tools
    • Use Hot air to soften the adhesive and gently remove the sup-bord
    • Its better to use a plastic tools
  9. To remove the Battery use a few drops of alcohol and warm the device. To remove the Battery use a few drops of alcohol and warm the device. To remove the Battery use a few drops of alcohol and warm the device.
    • To remove the Battery use a few drops of alcohol and warm the device.
  10. Now you have to transfer: Receiber Vibromotor
    • Now you have to transfer:
    • Receiber
    • Vibromotor
    • Loudspeacker
    • Remove the transport tapes from:
    • Silicon Thermal Pad
    • Front Camera Hole
    • Use Hot Air to do this easily
  11. Use Double side Adhesive tape to install the battery to the new frame
    • Use Double side Adhesive tape to install the battery to the new frame
  12. "All's Well That Ends Well."
    • "All's Well That Ends Well."
Conclusión
16 personas más completaron esta guía.
ZFix
Miembro Desde 09/12/13
183,565 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
306 Miembros
1,057 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 54
Ultimos 30 días: 207
Todo El Tiempo: 12,996
