Saltar al contenido principal
Samsung Exhibit II 4G Midframe Replacement
Qué necesitas
  1. Samsung Exhibit II 4G Midframe Replacement, Battery: paso 1, imagen 1 de 1
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
  2. Samsung Exhibit II 4G Midframe Replacement: paso 2, imagen 1 de 1
    • Insert plastic opening tool under battery.
    • Pry battery out.
  3. Samsung Exhibit II 4G Midframe Replacement, Top Rear Housing Cover: paso 3, imagen 1 de 1
    • Pry the top cover upward to remove it from the phone.
  4. Samsung Exhibit II 4G Midframe Replacement: paso 4, imagen 1 de 1
    • Remove the top cover.
  5. Samsung Exhibit II 4G Midframe Replacement: paso 5, imagen 1 de 2 Samsung Exhibit II 4G Midframe Replacement: paso 5, imagen 2 de 2
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
  6. Samsung Exhibit II 4G Midframe Replacement: paso 6, imagen 1 de 3 Samsung Exhibit II 4G Midframe Replacement: paso 6, imagen 2 de 3 Samsung Exhibit II 4G Midframe Replacement: paso 6, imagen 3 de 3
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
  7. Samsung Exhibit II 4G Midframe Replacement, Midframe: paso 7, imagen 1 de 1
    • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
  8. Samsung Exhibit II 4G Midframe Replacement: paso 8, imagen 1 de 1
    • Insert plastic opening tool between back assembly and phone.
    • Pry the back assembly away from phone.
  9. Samsung Exhibit II 4G Midframe Replacement: paso 9, imagen 1 de 1
    • With plastic opening tool continue prying around the edge of the back assembly.
  10. Samsung Exhibit II 4G Midframe Replacement: paso 10, imagen 1 de 1
    • Pull back panel assembly away from main body.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 252
