Introducción
Use this guide to replace a defective Loudspeaker.
Qué necesitas
Insert plastic opening tool under back cover.
Apply pressure on tool while using a downward motion to pop off back cover.
Pry the top cover upward to remove it from the phone.
Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
Position Back Panel Assembly so the internal Loudspeaker unit is facing up.
With your index fingers and thumbs, grasp the Back Panel Assembly near the Loudspeaker.
Twist your palms inward to apply pressure against your index fingers.
The Loudspeaker will easily pop out.
Una persona más ha completado esta guía.
