Saltar al contenido principal
Samsung Eternity Motherboard Replacement
Qué necesitas
    • Remove the back battery cover.
  1. Samsung Eternity Motherboard Replacement: paso 2, imagen 1 de 1
    • Using the Phillips #00 screwdriver, remove the phone's battery.
  2. Samsung Eternity Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver
  3. Samsung Eternity Motherboard Replacement: paso 4, imagen 1 de 2 Samsung Eternity Motherboard Replacement: paso 4, imagen 2 de 2
    • Continuing to use the Phillips #00 screwdriver, gently pry the silver plastic back plate from the body of the phone.
  4. Samsung Eternity Motherboard Replacement, Motherboard: paso 5, imagen 1 de 1
    • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
    • Pull the antenna plug out of its socket.
  5. Samsung Eternity Motherboard Replacement: paso 6, imagen 1 de 3 Samsung Eternity Motherboard Replacement: paso 6, imagen 2 de 3 Samsung Eternity Motherboard Replacement: paso 6, imagen 3 de 3
    • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
  6. Samsung Eternity Motherboard Replacement: paso 7, imagen 1 de 1
    • Pop the red hinged-release lever away from its ribbon. Then pull it out.
  7. Samsung Eternity Motherboard Replacement: paso 8, imagen 1 de 1
    • Peel the button sensor on the side of the motherboard off of the case.
  8. Samsung Eternity Motherboard Replacement: paso 9, imagen 1 de 3 Samsung Eternity Motherboard Replacement: paso 9, imagen 2 de 3 Samsung Eternity Motherboard Replacement: paso 9, imagen 3 de 3
    • Slightly pull up one side of the motherboard.
    • Pull the button/microphone plug out of its socket.
    • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
  9. Samsung Eternity Motherboard Replacement: paso 10, imagen 1 de 1
    • You have successfully removed the motherboard from the phone.
Conclusión
Kevin Huang
Miembro Desde 04/20/11
11 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 15-11, Regan Spring 2011 Miembro de Cal Poly, Team 15-11, Regan Spring 2011
CPSU-REGAN-S11S15G11
5 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 2,304
