Saltar al contenido principal
Samsung Eternity Digitizer and Screen Replacement
Qué necesitas
    • Remove the back battery cover.
  1. Samsung Eternity Digitizer and Screen Replacement: paso 2, imagen 1 de 1
    • Using the Phillips #00 screwdriver, remove the phone's battery.
  2. Samsung Eternity Digitizer and Screen Replacement: paso 3, imagen 1 de 1
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver
  3. Samsung Eternity Digitizer and Screen Replacement: paso 4, imagen 1 de 2 Samsung Eternity Digitizer and Screen Replacement: paso 4, imagen 2 de 2
    • Continuing to use the Phillips #00 screwdriver, gently pry the silver plastic back plate from the body of the phone.
  4. Samsung Eternity Digitizer and Screen Replacement, Motherboard: paso 5, imagen 1 de 1
    • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
    • Pull the antenna plug out of its socket.
  5. Samsung Eternity Digitizer and Screen Replacement: paso 6, imagen 1 de 3 Samsung Eternity Digitizer and Screen Replacement: paso 6, imagen 2 de 3 Samsung Eternity Digitizer and Screen Replacement: paso 6, imagen 3 de 3
    • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
  6. Samsung Eternity Digitizer and Screen Replacement: paso 7, imagen 1 de 1
    • Pop the red hinged-release lever away from its ribbon. Then pull it out.
  7. Samsung Eternity Digitizer and Screen Replacement: paso 8, imagen 1 de 1
    • Peel the button sensor on the side of the motherboard off of the case.
  8. Samsung Eternity Digitizer and Screen Replacement: paso 9, imagen 1 de 3 Samsung Eternity Digitizer and Screen Replacement: paso 9, imagen 2 de 3 Samsung Eternity Digitizer and Screen Replacement: paso 9, imagen 3 de 3
    • Slightly pull up one side of the motherboard.
    • Pull the button/microphone plug out of its socket.
    • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
  9. Samsung Eternity Digitizer and Screen Replacement: paso 10, imagen 1 de 1
    • You have successfully removed the motherboard from the phone.
  10. Samsung Eternity Digitizer and Screen Replacement, Digitizer and Screen: paso 11, imagen 1 de 1
    • Flip phone over so you are looking at the front screen of the phone. (The back is already taken off and parts removed)
  11. Samsung Eternity Digitizer and Screen Replacement: paso 12, imagen 1 de 3 Samsung Eternity Digitizer and Screen Replacement: paso 12, imagen 2 de 3 Samsung Eternity Digitizer and Screen Replacement: paso 12, imagen 3 de 3
    • Use a small tool to pry the digitizer and screen (together) from the frame of the phone. This may take some time and careful work because it is glued down to the frame.
    • Be careful when you pull the lower part of this piece away from the phone frame because there is a ribbon attached to the digitizer that you don't want to break. There is also a ribbon on the side of the screen to be aware of.
  12. Samsung Eternity Digitizer and Screen Replacement: paso 13, imagen 1 de 3 Samsung Eternity Digitizer and Screen Replacement: paso 13, imagen 2 de 3 Samsung Eternity Digitizer and Screen Replacement: paso 13, imagen 3 de 3
    • Next, carefully pull the digitizer away from the screen.
    • At this point you can replace either the screen or the digitizer.
    • Cleaning the screen with a glass cleaning cloth before reassembling will remove any smudges or fingerprints from disassembling the device.
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team 15-11, Regan Spring 2011 Miembro de Cal Poly, Team 15-11, Regan Spring 2011
CPSU-REGAN-S11S15G11
5 Miembros
14 Guías creadas
3 comentarios
You did not mention how to glue the digitizer to LCD. That is a very important step.
cashyapan - Contestar
Do these steps also work for the Samsung Eternity 2?
Brian Coukis The 90's Kid! - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 6,835
