Saltar al contenido principal
Samsung Epix Speakers Replacement
Qué necesitas
  1. Samsung Epix Speakers Replacement, Battery: paso 1, imagen 1 de 1
    • Press button on back of phone below camera.
    • While button is depressed, remove the back panel of the phone by it sliding off (not shown in picture).
  2. Samsung Epix Speakers Replacement: paso 2, imagen 1 de 1
    • Grasp the bottom corners of the battery with two fingers and gently lift.
  3. Samsung Epix Speakers Replacement, Speakers: paso 3, imagen 1 de 1
    • Using an iPod opening tool, remove the screw cover in the top left corner by lifting it up.
  4. Samsung Epix Speakers Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the six screws on the back of the phone. Three are evenly spaced on each side.
    • The upper right screw is 4.5mm while the rest are 6.5mm.
  5. Samsung Epix Speakers Replacement: paso 5, imagen 1 de 2 Samsung Epix Speakers Replacement: paso 5, imagen 2 de 2
    • Slide the iPod opening tool into the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
  6. Samsung Epix Speakers Replacement: paso 6, imagen 1 de 1
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It is still connected to the phone chassis by a ribbon cable in the bottom right corner of the motherboard.
  7. Samsung Epix Speakers Replacement: paso 7, imagen 1 de 1
    • Remove the circular battery from the plastic holder by inserting a 1 mm flat head screwdriver under the battery where the red and blue wires connect and lifting gently.
    • Make sure the battery is still connected to the motherboard via the red and blue wires. This part does not have to be completely removed.
  8. Samsung Epix Speakers Replacement: paso 8, imagen 1 de 1
    • Using a Phillips #00 screwdriver, unscrew the two 3.5mm screws that connect the speaker to the motherboard.
  9. Samsung Epix Speakers Replacement: paso 9, imagen 1 de 1
    • With the iPod opening tool, unclip the red and black wires connecting the speaker to the motherboard.
    • Lift the speaker off of the motherboard.
    • The camera will remain attached to the phone when removing the speaker.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 15-15, Regan Spring 2011 Miembro de Cal Poly, Team 15-15, Regan Spring 2011
CPSU-REGAN-S11S15G15
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 1,371
