Saltar al contenido principal
Samsung Epix LCD Display Replacement
Qué necesitas
  1. Samsung Epix LCD Display Replacement, Battery: paso 1, imagen 1 de 1
    • Press button on back of phone below camera.
    • While button is depressed, remove the back panel of the phone by it sliding off (not shown in picture).
  2. Samsung Epix LCD Display Replacement: paso 2, imagen 1 de 1
    • Grasp the bottom corners of the battery with two fingers and gently lift.
  3. Samsung Epix LCD Display Replacement, LCD Display: paso 3, imagen 1 de 1
    • Remove the rubber screw cover in the top left corner by prying upwards with an opening tool.
  4. Samsung Epix LCD Display Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the six screws on the back of the phone.
    • The upper right screw is 4.5 mm and the others are 6.5 mm.
  5. Samsung Epix LCD Display Replacement: paso 5, imagen 1 de 2 Samsung Epix LCD Display Replacement: paso 5, imagen 2 de 2
    • Slide the opening tool along the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
  6. Samsung Epix LCD Display Replacement: paso 6, imagen 1 de 1
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It will still be connected to the phone chassis by a ribbon cable on the motherboard.
  7. Samsung Epix LCD Display Replacement: paso 7, imagen 1 de 1
    • Using an opening tool, undo the ZIF connector halfway up the right side.
    • Carefully remove ribbon cable.
  8. Samsung Epix LCD Display Replacement: paso 8, imagen 1 de 1
    • Remove the front faceplate by lifting it off of the phone chassis.
  9. Samsung Epix LCD Display Replacement: paso 9, imagen 1 de 1
    • Using the opening tool, unlatch the LCD ribbon cable.
  10. Samsung Epix LCD Display Replacement: paso 10, imagen 1 de 1
    • Using an opening tool or spudger, pry under the lower left and right corners of the LCD screen.
    • The LCD is held in place to the chassis with adhesive strips.
    • Do not pry excessively hard. You may damage the circuitry on the back of the LCD.
  11. Samsung Epix LCD Display Replacement: paso 11, imagen 1 de 1
    • Lift the LCD display out from phone chassis.
Conclusión
Una persona más ha completado esta guía.
Mark Wyse
Miembro Desde 04/19/11
59 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 15-15, Regan Spring 2011 Miembro de Cal Poly, Team 15-15, Regan Spring 2011
CPSU-REGAN-S11S15G15
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 1,905
