Saltar al contenido principal
Samsung Epic 4G Touch microSD Card Replacement
Qué necesitas
  1. Samsung Epic 4G Touch microSD Card Replacement, Rear Case: paso 1, imagen 1 de 2 Samsung Epic 4G Touch microSD Card Replacement, Rear Case: paso 1, imagen 2 de 2
    • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
    • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
  2. Samsung Epic 4G Touch microSD Card Replacement: paso 2, imagen 1 de 2 Samsung Epic 4G Touch microSD Card Replacement: paso 2, imagen 2 de 2
    • Lift and remove the rear case.
  3. Samsung Epic 4G Touch microSD Card Replacement, microSD Card: paso 3, imagen 1 de 2 Samsung Epic 4G Touch microSD Card Replacement, microSD Card: paso 3, imagen 2 de 2
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • During reassembly, push the microSD card into the slot until it clicks in place.
  4. Samsung Epic 4G Touch microSD Card Replacement: paso 4, imagen 1 de 1
    • Pull the microSD card away from its slot.
Conclusión
3 personas más completaron esta guía.
2 comentarios
Uhh.... my Australian SGSII looks different to this...
Bonj - Contestar
If you are having trouble addint a 64gb micro sd card, it's because you have to first format that card to FAT32. You have to do that to the memory card through a computer. Youtube too, it'll help
asff - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 4,388
