Saltar al contenido principal
Samsung Epic 4G Battery Replacement
Qué necesitas
  1. Samsung Epic 4G Battery Replacement, Phone Case: paso 1, imagen 1 de 1
    • Slide your fingernail along the edge of the device and pull at the plastic backing.
    • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
  2. Samsung Epic 4G Battery Replacement: paso 2, imagen 1 de 1
    • Pull at the plastic backing gently to remove it after hearing the snap sound.
  3. Samsung Epic 4G Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Remove the battery from the device by pulling the battery edge upwards.
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team 24-25, Regan Fall 2012 Miembro de Cal Poly, Team 24-25, Regan Fall 2012
CPSU-REGAN-F12S24G25
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 2,093
