Introducción
This guide will show you how to remove the current screen on your Samsung Droid Charge and install a new one.
Qué necesitas
Open up the back case on the phone from the groove in the bottom of the phone.
Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
Push the SD card further into its metal slot until you hear a click.
Release the card, and it should automatically eject itself.
Remove the SD card.
Locate the 7 small black screws located around the edge of the phone under the battery cover.
With a small Philips head screwdriver, remove each of the screws and place them in a secure location.
5 personas más completaron esta guía.
