Saltar al contenido principal
Samsung Droid Charge Battery Replacement
Qué necesitas
  1. Samsung Droid Charge Battery Replacement, Rear Cover: paso 1, imagen 1 de 1
    • Open up the back case on the phone from the groove in the bottom of the phone.
    • You can do this by inserting a fingernail or similarly thin object into the groove and pulling up with mild force.
  2. Samsung Droid Charge Battery Replacement, Battery: paso 2, imagen 1 de 1
    • Below the left part of the bottom of the battery area there will be a groove large enough to fit in a finger or screw driver head.
    • Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
Conclusión
5 personas más completaron esta guía.
Luke Gordon
Miembro Desde 09/26/12
178 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 15-44, Forte Fall 2012 Miembro de Cal Poly, Team 15-44, Forte Fall 2012
CPSU-FORTE-F12S15G44
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 1,661
