Saltar al contenido principal
Samsung DVD-HD850 Player Disk Drive Motor Replacement
Qué necesitas
  1. Samsung DVD-HD850 Player Disk Drive Motor Replacement, Locate and Remove The Disk Tray: paso 1, imagen 1 de 1
    • *NOTE* remember to never connect to power when working on electrical components
    • Find and locate the disk tray it is located top right hand side of the component when the back of the device ( dvd player ) is facing you.
  2. Samsung DVD-HD850 Player Disk Drive Motor Replacement, Removing The Data Strips: paso 2, imagen 1 de 1
    • Locate and gently remove the data strips on the tray. There are three in total, two on the left hand side and one on the right.
  3. Samsung DVD-HD850 Player Disk Drive Motor Replacement, Removing The Screws: paso 3, imagen 1 de 3 Samsung DVD-HD850 Player Disk Drive Motor Replacement, Removing The Screws: paso 3, imagen 2 de 3 Samsung DVD-HD850 Player Disk Drive Motor Replacement, Removing The Screws: paso 3, imagen 3 de 3
    • As noted by the red circles, locate and remove the screws one at a time
  4. Samsung DVD-HD850 Player Disk Drive Motor Replacement, Disk Tray Removal: paso 4, imagen 1 de 1
    • After removing the clips slowly incline the disk drive towards you and unclip it from the two (2) brackets located on the top
    • Be careful not to push too much pressure on the brackets since they tend to break easily
  5. Samsung DVD-HD850 Player Disk Drive Motor Replacement, Success!: paso 5, imagen 1 de 1
    • Congrats! You have sucessfully have taken out the disk drive
  6. Samsung DVD-HD850 Player Disk Drive Motor Replacement, Disassemble the motor from the disk tray: paso 6, imagen 1 de 1
    • Remove screws as noted by the picture
  7. Samsung DVD-HD850 Player Disk Drive Motor Replacement, Removing Data Strips: paso 7, imagen 1 de 1
    • Slowly remove the circuit board/cables/strips from under the black bar. ( under and over)
    • Be careful not to pull it hard, due to these cable are fragile and can break easliy
  8. Samsung DVD-HD850 Player Disk Drive Motor Replacement, Replacing Motor: paso 8, imagen 1 de 1
    • Replace the motor in question ( usually both are needed to be replaced)
  9. Samsung DVD-HD850 Player Disk Drive Motor Replacement, Reassembly: paso 9, imagen 1 de 1
    • To reassembly do these steps in reverse order
Conclusión
Carlos
Miembro Desde 10/16/14
354 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 1-6, Duarte Fall 2014 Miembro de UMass Dartmouth, Team 1-6, Duarte Fall 2014
UMASSD-DUARTE-F14S1G6
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 18
Todo El Tiempo: 1,438
