Saltar al contenido principal
Samsung DV300F Lens Replacement
Qué necesitas
  1. Samsung DV300F Lens Replacement, Front and Rear Casing: paso 1, imagen 1 de 3 Samsung DV300F Lens Replacement, Front and Rear Casing: paso 1, imagen 2 de 3 Samsung DV300F Lens Replacement, Front and Rear Casing: paso 1, imagen 3 de 3
    • Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
  2. Samsung DV300F Lens Replacement: paso 2, imagen 1 de 2 Samsung DV300F Lens Replacement: paso 2, imagen 2 de 2
    • Remove the back case of the camera carefully.
  3. Samsung DV300F Lens Replacement: paso 3, imagen 1 de 3 Samsung DV300F Lens Replacement: paso 3, imagen 2 de 3 Samsung DV300F Lens Replacement: paso 3, imagen 3 de 3
    • Remove the front case of the camera.
    • Remove the front LCD screen from the front case next to the lens.
  4. Samsung DV300F Lens Replacement, Back Button Control: paso 4, imagen 1 de 2 Samsung DV300F Lens Replacement, Back Button Control: paso 4, imagen 2 de 2
    • Remove the blue button control from its position next to the LCD screen.
    • Pull the ribbon cable to disconnect the blue button control from the camera.
  5. Samsung DV300F Lens Replacement, Back LCD Screen: paso 5, imagen 1 de 1
    • Remove the back LCD screen from its place carefully.
  6. Samsung DV300F Lens Replacement: paso 6, imagen 1 de 2 Samsung DV300F Lens Replacement: paso 6, imagen 2 de 2
    • Flip the black tab where the back LCD screen connects to the circuit board.
    • Pull the tape connection to disconnect the back LCD screen from the circuit board.
  7. Samsung DV300F Lens Replacement, Lens: paso 7, imagen 1 de 2 Samsung DV300F Lens Replacement, Lens: paso 7, imagen 2 de 2
    • Unscrew the 3 silver #0 Phillips 4.45mm screws from the circuit board cover
    • Remove the circuit board cover
  8. Samsung DV300F Lens Replacement: paso 8, imagen 1 de 2 Samsung DV300F Lens Replacement: paso 8, imagen 2 de 2
    • Flip the first black tab connecting the lens to the circuit board
    • Flip the second black tab connecting the lens to the circuit board
    • Push the lens out from the front to remove it from the camera
Conclusión
5 personas más completaron esta guía.
Equipo
Baylor, Team 5-10, Williams Spring 2015 Miembro de Baylor, Team 5-10, Williams Spring 2015
BU-WILLIAMS-S15S5G10
3 Miembros
10 Guías creadas
Un comentario
pourquoi ne pas aussi montrer comment demonter le lens de samsung dv300f
nouzalek - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 16
Ultimos 30 días: 39
Todo El Tiempo: 2,066
