Saltar al contenido principal
Samsung DV300F Back Button Control Replacement
Qué necesitas
  1. Samsung DV300F Back Button Control Replacement, Front and Rear Casing: paso 1, imagen 1 de 3 Samsung DV300F Back Button Control Replacement, Front and Rear Casing: paso 1, imagen 2 de 3 Samsung DV300F Back Button Control Replacement, Front and Rear Casing: paso 1, imagen 3 de 3
    • Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
  2. Samsung DV300F Back Button Control Replacement: paso 2, imagen 1 de 2 Samsung DV300F Back Button Control Replacement: paso 2, imagen 2 de 2
    • Remove the back case of the camera carefully.
  3. Samsung DV300F Back Button Control Replacement: paso 3, imagen 1 de 3 Samsung DV300F Back Button Control Replacement: paso 3, imagen 2 de 3 Samsung DV300F Back Button Control Replacement: paso 3, imagen 3 de 3
    • Remove the front case of the camera.
    • Remove the front LCD screen from the front case next to the lens.
  4. Samsung DV300F Back Button Control Replacement, Back Button Control: paso 4, imagen 1 de 2 Samsung DV300F Back Button Control Replacement, Back Button Control: paso 4, imagen 2 de 2
    • Remove the blue button control from its position next to the LCD screen.
    • Pull the ribbon cable to disconnect the blue button control from the camera.
Conclusión
3 personas más completaron esta guía.
Equipo
Baylor, Team 5-10, Williams Spring 2015 Miembro de Baylor, Team 5-10, Williams Spring 2015
BU-WILLIAMS-S15S5G10
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 18
Ultimos 30 días: 21
Todo El Tiempo: 753
