Saltar al contenido principal
Samsung DV180F Repair Battery Replacement
Qué necesitas
  1. Samsung DV180F Repair Battery Replacement, Battery: paso 1, imagen 1 de 2 Samsung DV180F Repair Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Locate the battery door and slide it to the right to unlatch it. Swing the battery door up to expose the battery chamber.
    • Ensure that the camera is turned off before attempting to replace the battery.
  2. Samsung DV180F Repair Battery Replacement: paso 2, imagen 1 de 1
    • Locate the blue latch that holds the battery in the battery chamber. Using your fingernail or a plastic opening tool, push it away from the battery, in the direction of the arrow on the latch.
  3. Samsung DV180F Repair Battery Replacement: paso 3, imagen 1 de 2 Samsung DV180F Repair Battery Replacement: paso 3, imagen 2 de 2
    • Once the latch is disengaged, the battery should pop up. Grab the battery and slide it up and out of the camera.
  4. Samsung DV180F Repair Battery Replacement: paso 4, imagen 1 de 1
    • Move the blue latch out of the way and slide the replacement battery into the battery chamber. Lightly push until the battery clicks in place. Close the battery door.
    • Make sure that the replacement battery is oriented correctly.
Conclusión
maria
Miembro Desde 09/26/16
244 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 14-4, Eyestone Fall 2016 Miembro de USF Tampa, Team 14-4, Eyestone Fall 2016
USFT-EYESTONE-F16S14G4
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 411
