Saltar al contenido principal
Samsung DV180F Repair Back control buttons Replacement
Qué necesitas
  1. Samsung DV180F Repair Back control buttons Replacement, Back Buttons Panel: paso 1, imagen 1 de 2 Samsung DV180F Repair Back control buttons Replacement, Back Buttons Panel: paso 1, imagen 2 de 2
    • Ensure the camera is turned off and battery is taken out before you begin.
    • Remove the two external screws from the camera using a Phillips 000 screwdriver.
  2. Samsung DV180F Repair Back control buttons Replacement: paso 2, imagen 1 de 1
    • Insert a plastic opening tool in the gap between the camera body and back panel.
    • Pry along the right side of the camera to separate the back panel.
  3. Samsung DV180F Repair Back control buttons Replacement: paso 3, imagen 1 de 1
    • Once the camera is open, remove the two internal screws using a Phillips 000 screwdriver.
  4. Samsung DV180F Repair Back control buttons Replacement: paso 4, imagen 1 de 2 Samsung DV180F Repair Back control buttons Replacement: paso 4, imagen 2 de 2
    • Use a plastic opening tool to release the lock securing the ribbon receptor to the right side of the motherboard.
    • Ribbons have to be unlocked before removal to prevent damage.
  5. Samsung DV180F Repair Back control buttons Replacement: paso 5, imagen 1 de 1
    • Gently lift the circuit board from the camera.
    • Remove the display ribbon receptor lock to remove back panel from the motherboard.
  6. Samsung DV180F Repair Back control buttons Replacement: paso 6, imagen 1 de 2 Samsung DV180F Repair Back control buttons Replacement: paso 6, imagen 2 de 2
    • Remove back display.
    • Replace the back button panel.
Conclusión
maria
Miembro Desde 09/26/16
244 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 14-4, Eyestone Fall 2016 Miembro de USF Tampa, Team 14-4, Eyestone Fall 2016
USFT-EYESTONE-F16S14G4
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 383
