Saltar al contenido principal
Samsung Chromebook XE550C22 Wifi Card Replacement
Qué necesitas
  1. Samsung Chromebook XE550C22 Wifi Card Replacement, Back Panel: paso 1, imagen 1 de 3 Samsung Chromebook XE550C22 Wifi Card Replacement, Back Panel: paso 1, imagen 2 de 3 Samsung Chromebook XE550C22 Wifi Card Replacement, Back Panel: paso 1, imagen 3 de 3
    • Turn the power off before beginning this step.
    • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
  2. Samsung Chromebook XE550C22 Wifi Card Replacement: paso 2, imagen 1 de 2 Samsung Chromebook XE550C22 Wifi Card Replacement: paso 2, imagen 2 de 2
    • Remove the eight 7mm screws using the J0 Screwdriver.
  3. Samsung Chromebook XE550C22 Wifi Card Replacement: paso 3, imagen 1 de 3 Samsung Chromebook XE550C22 Wifi Card Replacement: paso 3, imagen 2 de 3 Samsung Chromebook XE550C22 Wifi Card Replacement: paso 3, imagen 3 de 3
    • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
    • Continue prying around the sides to release more brackets.
  4. Samsung Chromebook XE550C22 Wifi Card Replacement: paso 4, imagen 1 de 2 Samsung Chromebook XE550C22 Wifi Card Replacement: paso 4, imagen 2 de 2
    • After deconnecting all the brackets, pull the back panel away from the laptop.
    • Note: The back panel has some flex to it, don't be afraid to use some force.
  5. Samsung Chromebook XE550C22 Wifi Card Replacement, Battery: paso 5, imagen 1 de 2 Samsung Chromebook XE550C22 Wifi Card Replacement, Battery: paso 5, imagen 2 de 2
    • Remove the four 3mm screws holding the battery with the J0 screwdriver.
  6. Samsung Chromebook XE550C22 Wifi Card Replacement: paso 6, imagen 1 de 2 Samsung Chromebook XE550C22 Wifi Card Replacement: paso 6, imagen 2 de 2
    • Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
    • Do not lift the battery straight up. This will damage the battery's connectors.
  7. Samsung Chromebook XE550C22 Wifi Card Replacement, Wifi Card: paso 7, imagen 1 de 1
    • Locate the wifi card on the top left of the Chromebook.
  8. Samsung Chromebook XE550C22 Wifi Card Replacement: paso 8, imagen 1 de 3 Samsung Chromebook XE550C22 Wifi Card Replacement: paso 8, imagen 2 de 3 Samsung Chromebook XE550C22 Wifi Card Replacement: paso 8, imagen 3 de 3
    • Use only plastic tools for this step.
    • Use the spudger to detach the black and white cords from the wifi card.
  9. Samsung Chromebook XE550C22 Wifi Card Replacement: paso 9, imagen 1 de 3 Samsung Chromebook XE550C22 Wifi Card Replacement: paso 9, imagen 2 de 3 Samsung Chromebook XE550C22 Wifi Card Replacement: paso 9, imagen 3 de 3
    • Remove the 6mm screw from the top right corner of the card using the J0 screwdriver.
    • The wifi card will "pop-up".
  10. Samsung Chromebook XE550C22 Wifi Card Replacement: paso 10, imagen 1 de 2 Samsung Chromebook XE550C22 Wifi Card Replacement: paso 10, imagen 2 de 2
    • Using your hands, gently remove the card up and away from the Chromebook.
Conclusión
5 personas más completaron esta guía.
Linh Luu
Miembro Desde 09/11/17
312 Reputación
2 Guías creadas
Equipo
CSU Fullerton, Team S2-G7, Bruce Fall 2017 Miembro de CSU Fullerton, Team S2-G7, Bruce Fall 2017
CSUF-BRUCE-F17S2G7
Miembros de 3
14 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 17
Todo El Tiempo: 4,285
