Saltar al contenido principal
Samsung Chromebook XE550C22 Cooling Fan Replacement
Qué necesitas
  1. Samsung Chromebook XE550C22 Cooling Fan Replacement, Back Panel: paso 1, imagen 1 de 3 Samsung Chromebook XE550C22 Cooling Fan Replacement, Back Panel: paso 1, imagen 2 de 3 Samsung Chromebook XE550C22 Cooling Fan Replacement, Back Panel: paso 1, imagen 3 de 3
    • Turn the power off before beginning this step.
    • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
  2. Samsung Chromebook XE550C22 Cooling Fan Replacement: paso 2, imagen 1 de 2 Samsung Chromebook XE550C22 Cooling Fan Replacement: paso 2, imagen 2 de 2
    • Remove the eight 7mm screws using the J0 Screwdriver.
  3. Samsung Chromebook XE550C22 Cooling Fan Replacement: paso 3, imagen 1 de 3 Samsung Chromebook XE550C22 Cooling Fan Replacement: paso 3, imagen 2 de 3 Samsung Chromebook XE550C22 Cooling Fan Replacement: paso 3, imagen 3 de 3
    • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
    • Continue prying around the sides to release more brackets.
  4. Samsung Chromebook XE550C22 Cooling Fan Replacement: paso 4, imagen 1 de 2 Samsung Chromebook XE550C22 Cooling Fan Replacement: paso 4, imagen 2 de 2
    • After deconnecting all the brackets, pull the back panel away from the laptop.
    • Note: The back panel has some flex to it, don't be afraid to use some force.
  5. Samsung Chromebook XE550C22 Cooling Fan Replacement, Battery: paso 5, imagen 1 de 2 Samsung Chromebook XE550C22 Cooling Fan Replacement, Battery: paso 5, imagen 2 de 2
    • Remove the four 3mm screws holding the battery with the J0 screwdriver.
  6. Samsung Chromebook XE550C22 Cooling Fan Replacement: paso 6, imagen 1 de 2 Samsung Chromebook XE550C22 Cooling Fan Replacement: paso 6, imagen 2 de 2
    • Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
    • Do not lift the battery straight up. This will damage the battery's connectors.
  7. Samsung Chromebook XE550C22 Cooling Fan Replacement, Cooling Fan: paso 7, imagen 1 de 1
    • Locate the cooling fan and the heat sink on the top center of the Chromebook.
  8. Samsung Chromebook XE550C22 Cooling Fan Replacement: paso 8, imagen 1 de 3 Samsung Chromebook XE550C22 Cooling Fan Replacement: paso 8, imagen 2 de 3 Samsung Chromebook XE550C22 Cooling Fan Replacement: paso 8, imagen 3 de 3
    • Rotate the Chromebook 180 degrees so the fan is closest to you, and locate the fan power cable.
    • Disconnect the fan cable from the motherboard with the angled tweezers.
    • Be gentle and do not pull out the fan cable with excessive force. It will result with a non-working cooling fan and a damaged wire.
  9. Samsung Chromebook XE550C22 Cooling Fan Replacement: paso 9, imagen 1 de 3 Samsung Chromebook XE550C22 Cooling Fan Replacement: paso 9, imagen 2 de 3 Samsung Chromebook XE550C22 Cooling Fan Replacement: paso 9, imagen 3 de 3
    • Remove four identical 6mm screws from the heat sink labelled CPU using the J0 screwdriver.
    • Using your hands, gently lift up and pull away the heat sink.
  10. Samsung Chromebook XE550C22 Cooling Fan Replacement: paso 10, imagen 1 de 3 Samsung Chromebook XE550C22 Cooling Fan Replacement: paso 10, imagen 2 de 3 Samsung Chromebook XE550C22 Cooling Fan Replacement: paso 10, imagen 3 de 3
    • Remove the three identical 6mm screws from around the fan using the J0 screwdriver.
    • Using your hands, gently lift up the fan and pull it away from the laptop.
Conclusión
Una persona más ha completado esta guía.
Linh Luu
Miembro Desde 09/11/17
312 Reputación
2 Guías creadas
Equipo
CSU Fullerton, Team S2-G7, Bruce Fall 2017 Miembro de CSU Fullerton, Team S2-G7, Bruce Fall 2017
CSUF-BRUCE-F17S2G7
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 394
