Introducción
This guide will help you replace your speakers in your Chromebook by showing you step-by-step on how to remove it.
Qué necesitas
Lay the Chromebook down so that the bottom cover is facing upward.
Using a Phillips #00 screwdriver, remove all seven 5.5 mm screws from the back cover.
Casi Terminas!
Conclusión
