Saltar al contenido principal
Samsung Chromebook XE500C21-A03US Battery Replacement
Qué necesitas
  1. Samsung Chromebook XE500C21-A03US Battery Replacement, Back Cover: paso 1, imagen 1 de 3 Samsung Chromebook XE500C21-A03US Battery Replacement, Back Cover: paso 1, imagen 2 de 3 Samsung Chromebook XE500C21-A03US Battery Replacement, Back Cover: paso 1, imagen 3 de 3
    • Turn the power off before beginning this step.
    • Most Chromebooks contain rubber circle pads on each of the four corners to cover the screws. In order to remove the rubber pads, simply use any opening tool.
    • Lay the Chromebook down so that the bottom cover is facing upward.
    • Using a Phillips #00 screwdriver, remove all seven 5.5 mm screws from the back cover.
  2. Samsung Chromebook XE500C21-A03US Battery Replacement: paso 2, imagen 1 de 3 Samsung Chromebook XE500C21-A03US Battery Replacement: paso 2, imagen 2 de 3 Samsung Chromebook XE500C21-A03US Battery Replacement: paso 2, imagen 3 de 3
    • Place the opening tool in the divot between the spine of the Chromebook and the back cover.
    • Slowly glide and push down the end of the opening tool along all sides of the Chromebook to detach the brackets. You will hear the brackets detach.
  3. Samsung Chromebook XE500C21-A03US Battery Replacement: paso 3, imagen 1 de 2 Samsung Chromebook XE500C21-A03US Battery Replacement: paso 3, imagen 2 de 2
    • Using the opening tool, pry off the back cover of the Chromebook
    • Be gentle while prying to avoid breaking the back cover.
  4. Samsung Chromebook XE500C21-A03US Battery Replacement, Battery: paso 4, imagen 1 de 2 Samsung Chromebook XE500C21-A03US Battery Replacement, Battery: paso 4, imagen 2 de 2
    • Remove the four 3 mm screws using a Phillips #000 screwdriver.
  5. Samsung Chromebook XE500C21-A03US Battery Replacement: paso 5, imagen 1 de 2 Samsung Chromebook XE500C21-A03US Battery Replacement: paso 5, imagen 2 de 2
    • Carefully lift the top of the battery then pull it away from you to remove it.
    • Some batteries may be attached via a battery connector. Disconnect the battery connector by simply pulling straight up at its base.
Conclusión
Alexis Cortez
Miembro Desde 09/11/17
228 Reputación
2 Guías creadas
Equipo
CSU Fullerton, Team S2-G5, Bruce Fall 2017 Miembro de CSU Fullerton, Team S2-G5, Bruce Fall 2017
CSUF-BRUCE-F17S2G5
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 462
