Saltar al contenido principal
Samsung Chromebook Series 3 Speaker Replacement
Qué necesitas
  1. Samsung Chromebook Series 3 Speaker Replacement, Bottom Cover: paso 1, imagen 1 de 3 Samsung Chromebook Series 3 Speaker Replacement, Bottom Cover: paso 1, imagen 2 de 3 Samsung Chromebook Series 3 Speaker Replacement, Bottom Cover: paso 1, imagen 3 de 3
    • Lay the Chromebook down so that the bottom cover is facing up.
    • Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
  2. Samsung Chromebook Series 3 Speaker Replacement: paso 2, imagen 1 de 3 Samsung Chromebook Series 3 Speaker Replacement: paso 2, imagen 2 de 3 Samsung Chromebook Series 3 Speaker Replacement: paso 2, imagen 3 de 3
    • Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
  3. Samsung Chromebook Series 3 Speaker Replacement: paso 3, imagen 1 de 3 Samsung Chromebook Series 3 Speaker Replacement: paso 3, imagen 2 de 3 Samsung Chromebook Series 3 Speaker Replacement: paso 3, imagen 3 de 3
    • Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
    • It is not necessary to remove it completely. It just needs to be separated from the bottom cover.
  4. Samsung Chromebook Series 3 Speaker Replacement: paso 4, imagen 1 de 3 Samsung Chromebook Series 3 Speaker Replacement: paso 4, imagen 2 de 3 Samsung Chromebook Series 3 Speaker Replacement: paso 4, imagen 3 de 3
    • Pry off the bottom cover using a plastic opening tool.
  5. Samsung Chromebook Series 3 Speaker Replacement, Battery: paso 5, imagen 1 de 3 Samsung Chromebook Series 3 Speaker Replacement, Battery: paso 5, imagen 2 de 3 Samsung Chromebook Series 3 Speaker Replacement, Battery: paso 5, imagen 3 de 3
    • Remove six 3.5 mm screws holding the battery using a Phillips #00 screwdriver.
    • Pull out the battery partway in order to easily get to the battery connector.
  6. Samsung Chromebook Series 3 Speaker Replacement: paso 6, imagen 1 de 3 Samsung Chromebook Series 3 Speaker Replacement: paso 6, imagen 2 de 3 Samsung Chromebook Series 3 Speaker Replacement: paso 6, imagen 3 de 3
    • Disconnect the battery connector by pulling straight up at its base.
    • When reassembling, simply position the connector above it's original place, and push down.
  7. Samsung Chromebook Series 3 Speaker Replacement: paso 7, imagen 1 de 2 Samsung Chromebook Series 3 Speaker Replacement: paso 7, imagen 2 de 2
    • You can now remove the battery.
  8. Samsung Chromebook Series 3 Speaker Replacement, Speaker: paso 8, imagen 1 de 3 Samsung Chromebook Series 3 Speaker Replacement, Speaker: paso 8, imagen 2 de 3 Samsung Chromebook Series 3 Speaker Replacement, Speaker: paso 8, imagen 3 de 3
    • Disconnect the cable connecting the speakers to the motherboard by pulling on it away from the motherboard.
  9. Samsung Chromebook Series 3 Speaker Replacement: paso 9, imagen 1 de 3 Samsung Chromebook Series 3 Speaker Replacement: paso 9, imagen 2 de 3 Samsung Chromebook Series 3 Speaker Replacement: paso 9, imagen 3 de 3
    • Lift up the piece of tape covering the trackpad ribbon cable.
    • Lift up the lock on the trackpad ribbon cable using a plastic opening tool.
    • Disconnect the trackpad ribbon cable by pulling it out.
  10. Samsung Chromebook Series 3 Speaker Replacement: paso 10, imagen 1 de 2 Samsung Chromebook Series 3 Speaker Replacement: paso 10, imagen 2 de 2
    • Lift up the trackpad ribbon cable so that it is not covering the speaker wire.
    • Lift up the two pieces of metallic tape so that they no longer cover the speaker wire.
    • When reassembling the device, make sure to lay down the metallic tape in the same place it was prior to disassembly. The tape serves as a connector for certain electrical circuits that should not be disconnected.
  11. Samsung Chromebook Series 3 Speaker Replacement: paso 11, imagen 1 de 3 Samsung Chromebook Series 3 Speaker Replacement: paso 11, imagen 2 de 3 Samsung Chromebook Series 3 Speaker Replacement: paso 11, imagen 3 de 3
    • Unscrew the four 3.7 mm screws holding down the speakers using a Phillips #00 screwdriver.
  12. Samsung Chromebook Series 3 Speaker Replacement: paso 12, imagen 1 de 2 Samsung Chromebook Series 3 Speaker Replacement: paso 12, imagen 2 de 2
    • Pull the speakers up to remove them.
Conclusión
7 personas más completaron esta guía.
Andrey Radchishin
Miembro Desde 01/21/15
1,833 Reputación
4 Guías creadas
Equipo
UWT Liner: Group 1 Miembro de UWT Liner: Group 1
Community
5 Miembros
8 Guías creadas
Un comentario
Many thanks.
Excellent guide .
Triumph Trident - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 1,527
