Saltar al contenido principal
Samsung Chromebook Series 3 Front Camera Replacement
Qué necesitas
  1. Samsung Chromebook Series 3 Front Camera Replacement, Screen: paso 1, imagen 1 de 3 Samsung Chromebook Series 3 Front Camera Replacement, Screen: paso 1, imagen 2 de 3 Samsung Chromebook Series 3 Front Camera Replacement, Screen: paso 1, imagen 3 de 3
    • Use the iFixit opening tool to get under the front cover and pop it out of place
  2. Samsung Chromebook Series 3 Front Camera Replacement: paso 2, imagen 1 de 3 Samsung Chromebook Series 3 Front Camera Replacement: paso 2, imagen 2 de 3 Samsung Chromebook Series 3 Front Camera Replacement: paso 2, imagen 3 de 3
    • Remove the four 2.9 mm screws with the Phillips #00 Screwdriver bit.
    • Using the iFixit opening tool, try to lift up the screen (it is held down by some adhesive).
  3. Samsung Chromebook Series 3 Front Camera Replacement: paso 3, imagen 1 de 3 Samsung Chromebook Series 3 Front Camera Replacement: paso 3, imagen 2 de 3 Samsung Chromebook Series 3 Front Camera Replacement: paso 3, imagen 3 de 3
    • Lift the lever to release the cable and pull the cable out.
  4. Samsung Chromebook Series 3 Front Camera Replacement: paso 4, imagen 1 de 1
    • You can now remove the screen.
  5. Samsung Chromebook Series 3 Front Camera Replacement, Front Camera: paso 5, imagen 1 de 3 Samsung Chromebook Series 3 Front Camera Replacement, Front Camera: paso 5, imagen 2 de 3 Samsung Chromebook Series 3 Front Camera Replacement, Front Camera: paso 5, imagen 3 de 3
    • Disconnect the ribbon cable connected to the front camera assembly.
    • You will need to flip up the little black lever to release the cable.
  6. Samsung Chromebook Series 3 Front Camera Replacement: paso 6, imagen 1 de 2 Samsung Chromebook Series 3 Front Camera Replacement: paso 6, imagen 2 de 2
    • Use an iFixit opening tool to pry the front camera assembly from the adhesive holding it in place.
Conclusión
Tyler Schultz
Miembro Desde 03/25/19
555 Reputación
3 Guías creadas
Equipo
IUPUI, Team S2-G1, Henning Spring 2019 Miembro de IUPUI, Team S2-G1, Henning Spring 2019
IUPUI-HENNING-S19S2G1
3 Miembros
6 Guías creadas
Un comentario
Thanks for posting this! I looked all over youtube and couldn’t find anything so I am relieved to find this tutorial! I haven’t performed the repair yet, but I was wondering if removing the screen is necessary. From what I see, I can access the camera by just removing the bezel. Thanks for your feedback in advance!
Angel Knepper - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 413
