Saltar al contenido principal
Samsung Chromebook 3 XE500C13-K02US Speakers Replacement
Qué necesitas
  1. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement, Bottom Case: paso 1, imagen 1 de 2 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement, Bottom Case: paso 1, imagen 2 de 2
    • Place the laptop back cover facing up to expose the screws.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: paso 2, imagen 1 de 2 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: paso 2, imagen 2 de 2
    • Use an iFixit opening tool to wedge in between the case and body of the laptop.
    • Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
    • You should hear a popping sound as you slide the iFixit opening tool around the laptop.
  3. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: paso 3, imagen 1 de 2 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: paso 3, imagen 2 de 2
    • Remove the cover exposing the inside of the laptop.
  4. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement, Battery: paso 4, imagen 1 de 2 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement, Battery: paso 4, imagen 2 de 2
    • Remove the four 4.6mm screws with the Phillips #00 screwdriver.
  5. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: paso 5, imagen 1 de 3 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: paso 5, imagen 2 de 3 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: paso 5, imagen 3 de 3
    • Use the spudger to pry underneath the cable and gently lift the connector up.
  6. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: paso 6, imagen 1 de 1
    • Lift the battery up and out of the case.
  7. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement, Speakers: paso 7, imagen 1 de 2 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement, Speakers: paso 7, imagen 2 de 2
    • Remove two 4.9mm silver screws with a Phillips #00 screwdriver.
    • Each speaker only has 1 screw.
  8. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: paso 8, imagen 1 de 2 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: paso 8, imagen 2 de 2
    • Use the spudger to pry the speaker connector sideways out out of the motherboard.
    • Repeat this step for the left speaker.
  9. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: paso 9, imagen 1 de 1
    • Remove the speakers by lifting them upwards and out of the laptop.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 259
