Introducción
This guide is intended for the removal/replacement of the hinges in a Samsung Chromebook 3 XE500C13-K02US. It could also serve as guide for similar models. To do so, the bottom case has to be removed, then the wires running from the hinges to I/O board are disconnected. Afterwards, there are a couple of screws that are removed, then the nuts and washers holding the hinge.
Qué necesitas
Place the laptop back cover facing up to expose all nine 4.6 mm screws.
Remove all nine 4.6 mm screws using a Phillips #00 screwdriver.
Una persona más ha completado esta guía.
