Saltar al contenido principal
Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement
Qué necesitas
  1. Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement, Bottom Case: paso 1, imagen 1 de 2 Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement, Bottom Case: paso 1, imagen 2 de 2
    • Place the laptop back cover facing up to expose the screws.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement: paso 2, imagen 1 de 2 Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement: paso 2, imagen 2 de 2
    • Use an iFixit opening tool to wedge in between the case and body of the laptop.
    • Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
    • You should hear a popping sound as you slide the iFixit opening tool around the laptop.
  3. Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement: paso 3, imagen 1 de 2 Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement: paso 3, imagen 2 de 2
    • Remove the cover exposing the inside of the laptop.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 317
