Saltar al contenido principal
Samsung Chromebook 3 Daughterboard Replacement
Qué necesitas
  1. Samsung Chromebook 3 Daughterboard Replacement, Bottom Case: paso 1, imagen 1 de 2 Samsung Chromebook 3 Daughterboard Replacement, Bottom Case: paso 1, imagen 2 de 2
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Daughterboard Replacement: paso 2, imagen 1 de 3 Samsung Chromebook 3 Daughterboard Replacement: paso 2, imagen 2 de 3 Samsung Chromebook 3 Daughterboard Replacement: paso 2, imagen 3 de 3
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Daughterboard Replacement: paso 3, imagen 1 de 1
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Daughterboard Replacement, Battery: paso 4, imagen 1 de 2 Samsung Chromebook 3 Daughterboard Replacement, Battery: paso 4, imagen 2 de 2
    • Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
  5. Samsung Chromebook 3 Daughterboard Replacement: paso 5, imagen 1 de 2 Samsung Chromebook 3 Daughterboard Replacement: paso 5, imagen 2 de 2
    • Use a spudger to gently pry the power cable cord upwards from the motherboard.
  6. Samsung Chromebook 3 Daughterboard Replacement: paso 6, imagen 1 de 1
    • Lift the battery up and out from the case.
  7. Samsung Chromebook 3 Daughterboard Replacement, Daughterboard: paso 7, imagen 1 de 2 Samsung Chromebook 3 Daughterboard Replacement, Daughterboard: paso 7, imagen 2 de 2
    • Before you begin the process of removing the daughterboard, you will need to remove the port case. Using a Phillips #00 screwdriver, remove the three 4.6mm screws.
  8. Samsung Chromebook 3 Daughterboard Replacement: paso 8, imagen 1 de 2 Samsung Chromebook 3 Daughterboard Replacement: paso 8, imagen 2 de 2
    • Use a spudger to unhook the cable connecter from the speaker cable.
  9. Samsung Chromebook 3 Daughterboard Replacement: paso 9, imagen 1 de 3 Samsung Chromebook 3 Daughterboard Replacement: paso 9, imagen 2 de 3 Samsung Chromebook 3 Daughterboard Replacement: paso 9, imagen 3 de 3
    • Pry the small coaxial cables upwards from the connecters on the wireless chip.
  10. Samsung Chromebook 3 Daughterboard Replacement: paso 10, imagen 1 de 2 Samsung Chromebook 3 Daughterboard Replacement: paso 10, imagen 2 de 2
    • Using the Phillips #00, unscrew one 4.6mm screw from the daughterboard.
  11. Samsung Chromebook 3 Daughterboard Replacement: paso 11, imagen 1 de 3 Samsung Chromebook 3 Daughterboard Replacement: paso 11, imagen 2 de 3 Samsung Chromebook 3 Daughterboard Replacement: paso 11, imagen 3 de 3
    • Use a spudger to lift the gray plastic bar on the zif connecter up, then use your fingers to remove the cable ribbon.
  12. Samsung Chromebook 3 Daughterboard Replacement: paso 12, imagen 1 de 1
    • Loosen the daughterboard from the USB port with a spudger as there is some adhesive underneath, and you're ready to remove the daughterboard.
Conclusión
3 personas más completaron esta guía.
Sarah Westberg
Miembro Desde 03/11/19
19,003 Reputación
69 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
141 Miembros
17,709 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 17
Todo El Tiempo: 1,054
