Saltar al contenido principal
Samsung Chromebook 2 XE503c12 Speakers Replacement
Qué necesitas
  1. Samsung Chromebook 2 XE503c12 Speakers Replacement, Battery: paso 1, imagen 1 de 2 Samsung Chromebook 2 XE503c12 Speakers Replacement, Battery: paso 1, imagen 2 de 2
    • Flip device over so that the underside is facing up.
    • Remove nine, 7mm PH#0 screws from the bottom.
  2. Samsung Chromebook 2 XE503c12 Speakers Replacement: paso 2, imagen 1 de 2 Samsung Chromebook 2 XE503c12 Speakers Replacement: paso 2, imagen 2 de 2
    • Using the plastic opening tool, pry open the bottom of the Chromebook case, working all around the computer.
    • Lift the panel out of the way to reveal the battery.
  3. Samsung Chromebook 2 XE503c12 Speakers Replacement: paso 3, imagen 1 de 2 Samsung Chromebook 2 XE503c12 Speakers Replacement: paso 3, imagen 2 de 2
    • Remove four, 5mm Phillips #0 screws connecting the battery to the laptop
  4. Samsung Chromebook 2 XE503c12 Speakers Replacement: paso 4, imagen 1 de 1
    • Lift the battery, and pull it up and towards you, away from the connector.
    • Be sure to lift gently to avoid damage to connector
  5. Samsung Chromebook 2 XE503c12 Speakers Replacement: paso 5, imagen 1 de 1
    • Using a plastic opening tool, pry the connector up from the contact.
    • Remove the battery from the device.
  6. Samsung Chromebook 2 XE503c12 Speakers Replacement, Speakers: paso 6, imagen 1 de 2 Samsung Chromebook 2 XE503c12 Speakers Replacement, Speakers: paso 6, imagen 2 de 2
    • Remove the connectors for each speaker.
  7. Samsung Chromebook 2 XE503c12 Speakers Replacement: paso 7, imagen 1 de 1
    • Remove two 7mm Phillips #0 screws from each speaker.
    • Pull speakers out of laptop.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 115
