Introducción
Following this guide will help you remove and replace the motherboard on a Samsung Chromebook 2 XE503c12.
Qué necesitas
Flip device over so that the underside is facing up.
Remove nine, 7mm PH#0 screws from the bottom.
Locate the motherboard at top right of chromebook.
Remove four 9mm Phillips #0 screws and two 7mm Phillips #0 screws.
2 personas más completaron esta guía.
