Saltar al contenido principal
Samsung Chromebook series 5 XE550C22 SSD Replacement
Qué necesitas
  1. Samsung Chromebook series 5 XE550C22 SSD Replacement, Back Panel: paso 1, imagen 1 de 3 Samsung Chromebook series 5 XE550C22 SSD Replacement, Back Panel: paso 1, imagen 2 de 3 Samsung Chromebook series 5 XE550C22 SSD Replacement, Back Panel: paso 1, imagen 3 de 3
    • Turn the power off before beginning this step.
    • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
  2. Samsung Chromebook series 5 XE550C22 SSD Replacement: paso 2, imagen 1 de 2 Samsung Chromebook series 5 XE550C22 SSD Replacement: paso 2, imagen 2 de 2
    • Remove the eight 7mm screws using the J0 Screwdriver.
  3. Samsung Chromebook series 5 XE550C22 SSD Replacement: paso 3, imagen 1 de 3 Samsung Chromebook series 5 XE550C22 SSD Replacement: paso 3, imagen 2 de 3 Samsung Chromebook series 5 XE550C22 SSD Replacement: paso 3, imagen 3 de 3
    • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
    • Continue prying around the sides to release more brackets.
  4. Samsung Chromebook series 5 XE550C22 SSD Replacement: paso 4, imagen 1 de 2 Samsung Chromebook series 5 XE550C22 SSD Replacement: paso 4, imagen 2 de 2
    • After deconnecting all the brackets, pull the back panel away from the laptop.
    • Note: The back panel has some flex to it, don't be afraid to use some force.
  5. Samsung Chromebook series 5 XE550C22 SSD Replacement, Battery: paso 5, imagen 1 de 2 Samsung Chromebook series 5 XE550C22 SSD Replacement, Battery: paso 5, imagen 2 de 2
    • Remove the four 3mm screws holding the battery with the J0 screwdriver.
  6. Samsung Chromebook series 5 XE550C22 SSD Replacement: paso 6, imagen 1 de 2 Samsung Chromebook series 5 XE550C22 SSD Replacement: paso 6, imagen 2 de 2
    • Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
    • Do not lift the battery straight up. This will damage the battery's connectors.
  7. Samsung Chromebook series 5 XE550C22 SSD Replacement, SSD: paso 7, imagen 1 de 1
    • Locate the SSD in the center of the Chromebook.
  8. Samsung Chromebook series 5 XE550C22 SSD Replacement: paso 8, imagen 1 de 3 Samsung Chromebook series 5 XE550C22 SSD Replacement: paso 8, imagen 2 de 3 Samsung Chromebook series 5 XE550C22 SSD Replacement: paso 8, imagen 3 de 3
    • Remove the single 3.5mm screw using the J0 screwdriver.
    • The SSD should "pop-up" on its own after it's unscrewed.
  9. Samsung Chromebook series 5 XE550C22 SSD Replacement: paso 9, imagen 1 de 2 Samsung Chromebook series 5 XE550C22 SSD Replacement: paso 9, imagen 2 de 2
    • Pull the SSD up and away from the Chromebook
Conclusión
4 personas más completaron esta guía.
Abel Osorio
Miembro Desde 09/11/17
330 Reputación
2 Guías creadas
Equipo
CSU Fullerton, Team S2-G7, Bruce Fall 2017 Miembro de CSU Fullerton, Team S2-G7, Bruce Fall 2017
CSUF-BRUCE-F17S2G7
3 Miembros
14 Guías creadas
4 comentarios
Hello where can I get I higher SSD to buy
aduboa moses - Contestar
The SSD on the Chromebook 3 is non-upgradable. This is a different model. Please post this guide in the model you have.
frontiergds - Contestar
If you want to get more storage out of your chromebook get a sd card and you will only need it if you have a chrultrabook.
Will F - Contestar
The samsung chromebook shown on this guide is Samsung Chromebook XE550C22. The samsung chromebook 3 ( XE500C13 ), is totally different model. I have edited the title and description to match the actual model.
coldspring21 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 46
Todo El Tiempo: 5,105
